Not sure if it’s been mention, here’s something you can take a look at. Jeep delivered the vehicle with a spring in the lower radiator hose. They placed this spring in this position to prevent the hose from collapsing under load (such as higher rpm’s and highway driving).
See if this spring is in place. Or if the hose is squishy, install a high quality radiator hose (Continental) that resists collapsing.
Check your coolant mixture, should be a 50:50 mix.
