You don't have to take it too seriously. Look at mine, completely uneducational but you still get to see what I'm up to!!
MR2! Rock It baby!
Right now we have too much busy-ness and it really is not a good time.
I have been taking notes and pics. I plan to have a build thread when/if things slow down.
Have you driven it much?
Thoughts on the 5.89's?
Less than 500 miles. That would require a lot of time to explain. I guess the short answer is theyāre fine.
It's the long term part that will take a while... And Off-Road you liked them correct?
Fine off-road. No issues. The 42rle needs all it can get.temps stayed about 210 wheelin. On highway they got up about 200 on longer hills.
The issues will be sorting out what happens over 60mph. Iāve done some work there, but Iām not too worried about it. I donāt drive it much and going 80 isnāt my goal. Iāve had it up to 89mph.
So it does still have vibes?
.... Most people just wonder if itās even possible to put 589ās in Rubi Dana 44ās. Iā m like, āwellā¦theyāre in there.ā
I donāt think things would be too different with 538ās or 513ās.
Driveshaft rpms
The vibes wouldnāt be too much different. Maybe come on at 63 rather than 60, but vibes are vibes.
It's a known issue with the 42rle paired with the 241, specifically. And a big reason for locking hubs to disrupt the harmonics.
All it requires is a new pair of lockers. People lack imagination.![]()
33-splinemy curiosity is peaked here. Always operated under assumption 5.38's was limit. When you say change lockers and it can be done, how so? Genuinely curious as i have 42rle and 4.88's right now and would very much like 5.38's or lower as it never sees the freeway.
I'm curious how well the pinion will hold up on Jeremy's setup. I'd like to see the side by side of the pinion in the 5.89's compared to 5.38's.
According to Rory at Trailmater, you shouldn't run anything lower than 4.88's in Moab as it's just a matter of time before you fail the gears but many of us do it anyway and I'm yet to hear anything to give me concern. But, 5.89's is a considerable drop from what's commonly run around this forum.
Get to 5.38's for highway driving then you can look at improving the crawl ratios in other ways.
