I bought a new hood as I really struggled with my old cheap one. Settled on a Lincoln 1740. All I can say is holy shit what a difference! I can see EVERYTHING now where I couldn't before. I opted to get some cheaters for it too and it really helps with my vision. Very first weld with it as a test to see.
What's different about it vs your previous hood that lets you see so much better?
I don't know. Part of it might be the cheater lenses I bought. But everything is just crystal clear. For shits and giggles a changed out the lens protectors on my other two hoods so everything was new across the board for comparison. I'm going to try and video the differences if I can find a way to make it work.
Now that you have an idea of how crisp everything is supposed to look, you'll know when it's time to change out the clear lenses.
I've got a question for the welders in the forum.
I'm going to install the rear antirock and reading the instructions it says.
"You’ll need to fully weld the tabs into place, but you’ll need to do it very slowly so as not to warp the axle housing! Weld a very small amount on each side and then allow to completely cool before going back and adding more weld. The finished, welded tabs should look like this."
Now I've never welded in my life and I planned on paying someone else to do that step.
How much is a very small amount and how long do you have to wait for it to cool down?
It makes sense that welding a truss could possibly warp the axle but I was surprised to see the warning on this item.
Cool down doesn't necessarily mean "cool". Typically "cool down" is still warm to the touch ≈ 150° which should take about 10 - 20 min depending on how much heat was put into it during welding.
As for "a very small amount" I'd probably need more specifics. Can you post a link to the one you bought?
Not to piss in any of the expert's cheerios but this is a case of CYA and theory not quite standing up to practical application. I know this from experience welding lots of brackets and tabs on axle tubes with zero ill effect. I needed a way to show that it isn't as bad as lots of folks tend to make it out to be so I dug in the pile and retrieved a piece of front axle tube and an equivalent to the AR tab in an old control arm tab. It wasn't fully correct for the smaller 2.5" diameter on the .250 wall front tube so I ground it out to fit and also to really increase the amount of contact with the tube to ensure a worst case scenario with how far the weld goes around the tube.
For reference, the rear axle tube is the same wall thickness and slightly larger in diameter at 2 5/8" IIRC.
I cleaned it and then welded it hotter than normal after checking the tube with a straight edge to ensure straightness and it was. I welded both sides, one right after the other with the only pause between being the length of time it takes to move from one side to the other. I did two large tacks, one at each end and then went right to welding. This is the end result in pics.
You can tell by the small bit of spatter and smoke that I'm a tad hotter than I should be, by design.
End result is the tube is exactly as straight as it was before I started.
Nice experiment and weld looks great. I also didn’t realize less splatter could indicate high heat. How about if you weld longitudinally? Would that make a difference?
More spatter is from staying in the puddle too long and it starts popping a bit instead of the nice smooth buzz…
Axle tubes are really that thick?
I see in your last pic that you've turned a Carpenter's square into a Weldor's square. I've "cut corners" too.![]()
