Yukon knock off diff cover from ebay
Don Bulee
Mex
Do anyone have any experience with this Yukon knock off from ebay? Looks pretty much the same, but not sure if I should cheap a little bit.. I currently have the aluminium that is in the second picture.. Not sure if this would be considered an "upgrade"
What is not working with the existing cover?
If you like the Yukon cover, shouldn't you buy one from Yukon instead of a copy?
The existing leaks from all places and is pretty beaten... But I agree with getting the Yukon... You are right... And, after the break in process for the new gears installed, (500 miles per RGA webpage) should I remove the diff cover and make a complete change and cleaning? Or just draining the existing fluid and adding new one by using the drain plug in the Yukon cover would be enough?
