Recommended Electrical Connectors?
Another question for the group:
Why butt connectors instead of "parallel" connectors? If I understand correctly, a butt connector (whether split, brazed, or solid barrel) doesn't allow the two ends of the wire to come into contact with each other. Instead, the connector itself is the conduit between them. But a parallel connector, or an open-barrel connector, would allow the wires to be in direct contact with each other, even allowing for some solder if needed. Isn't a direct connection always better?
As Blaine said parallel are bulky. Open barrel are not but they are incredibly difficult to do in tight quarters compared to a butt connector.
Reactions: SSTJ
Got it, thanks. And I guess that if trusting the butt connector to be a good conduit was actually a bad idea, we would have learned that by now.
I use non insulated so I can ensure a good crimp. Heat shrink butt connectors are a thing I don’t agree with. It’s difficult to get a good crimp without compromising the heat shrink.
I prefer Molex brand for non insulated butt connectors and use their crimping plier made for the connectors. I find that ironic because I hate working with Molex connectors.
Use the Del City heat shrink butt connectors with the staking side of the crimp tool. Even if you manage to punch through the heat shrink, the adhesive seals the hole without any adverse damage to the connection whatsoever.
It is exactly the same crimp as a non insulated, I promise.
Reactions: JMT
The crimpers i use will destroy the heat shrink but Ill try some this weekend as a test.
If you want to save some coin, browse Waytek Wire. they sell the perma seal heat shrink butt connectors for almost 1/3 the price of del city.
https://www.waytekwire.com/wps/port...MIQqwGNGJNAN5jhNCDYFOxKvgoLcCIMsU4t0AM38bfU!/
I don't want to save coin, I want to use heat shrink butt connectors that you can't hurt the insulation on, so I do.
They did well with the standard crimping pliers. Still far too bulky for my likings. You should try the perma seal butt connectors. I believe it’s a much thinner heat shrink.
I don't use them where I am worried about bulk. I use them where I need a sealed connection and bulk doesn't matter and I know how to stagger them in a 2-5 wire harness so they don't cause an issue. If I have a bulk problem to solve, I use uninsulated barrels and adhesive lined heat shrink.
Reactions: NashvilleTJ
Good information in this thread. I have a mess of electrical work that I'd like to redo this year and really clean things up. I'd like to get everything in loom as well and my relays all in one area.
I just placed my order at Del City. For now, just butt connectors and heat shrink and "thrifty" wire spools. Couldn't afford to get 100 each of the other connectors, because there are so many variations (10 gauge ring for a #8 stud, 12 gauge ring for a #8 stud, 12 gauge ring for a #8 stud, 12 gauge ring for a #8 stud, etc. etc.).
Maybe next time I'll start a thread to see who wants to go in on a big Del City order, then divvy it all up.
I started another thread recently for pics of aux panel locations. I'm also preparing to re-do all my wiring at some point.
Reactions: JMT
Did you ever do a big order of Del City connectors?
I did order some basics: connectors of various sizes, and some of their smaller spools of wire, and some heat shrink. It was a bit pricey, but I don't do tons of electrical work, so it should last me a while. I'm about to start wiring some new fogs and aux reverse lights, so it'll go to good use.
Take a look at Sherco Automotive.
Do you use them instead of Del City for anything in particular? Let me know and I'll update the original post for others who come across this thread.
We are starting to use them more for the stuff that is equivalent quality to DC. I don't have a giant list yet but their brazed barrel or solid barrel butt connectors are top notch at far better prices. I also tried some samples of the translucent adhesive lined heat shrink and while still as bulky as the stuff from DC, it is far more economical.
Reactions: SSTJ
Ok, I'm returning to this thread to ask a related question. Most of the discussion so far has been about connecting individual wires. But now I'm interested in multi-pin connectors. So this brings back up the pros and cons of, say, Molex or WeatherPack or Deutsch.
I think I just listed those three in increasing order of price, quality, and difficulty for a beginner. Yes? Or is there another brand that's known as the go-to equivalent of whatever was originally used in our TJs?
Other than the cost, you won't find much better than Deutsch.
In my experience the Deutsch DT connectors are the best for general all around use. They have good sealing and the crimps almost never fail. They are also probably the most expensive option in the home game market. A good Deutsch crimper is $400.
My second choice and the ones I use on my LJ are the Metripack. The 150 series is good for overall use up to 15 amps or so. Then they have a 280 and 480 series for the higher load stuff. Crimpers are cheap and there are some good quality units on Amazon and eBay. They are decently easy to service in the field and most parts stores have components for them.
My last choice would be Weatherpack. It's an older technology. The biggest issue I have with them is the pins. They use a round style pin that has a tendency to misalign and unseat.
Chrysler used a grab bag of connectors from the factory. Depends on the component manufacturer as well as who they owed money to at the time. Most TJs used the Apex 2.8 series connector on the Chrysler parts. They are still available from Delphi or Aptiv or whoever they are today. They use a similar crimper to the Metripack and Weatherpack. Other sensors use Sumitomo connectors and there are also some Tyco and Molex sprinkled in for whatever reason.
