The only things that helped were (a) heavy skid plate (b) noico. One added more mass and one helped muffle the vibration. Nothing else, I mean NOTHING else really did anything meaningful.
this is still processing in my head, and I'm gonna use this thread to talk it out with myself.
My understanding of resonant frequencies is based pretty much entirely on stringed musical instruments. When I think about a guitar string - the resonant frequency shifts UP with a reduction in mass, and with an increase in rigidity, which the only analog I can come up with there is the tension in the string (rigidity->resistance to movement->string tension).
So if a skid plate (or any other component) is resonating, you would want to
increase the rigidity and/or
reduce the mass to move it's resonance upward and out of the range that the driveline can reach (above 70Hz should do it in most cases), or
reduce the rigidity/increase the mass to move it downward and into a range where the off-balance forces of the driveshaft aren't intense enough to excite it. Also want to consider that for a given material and thickness, adding mass (such as tacking on some damping weight) might have the opposite effect since it's inertia would mimic a reduction in rigidity. Then the question becomes...which is the right direction to go?
The Barnes skid plate increases mass by being 1/4" thick steel, and who knows about the rigidity. 1/4" thick steel would be more rigid, but it also lacks the stiffening features that the stock skid or the UCF or effectively, the savvy crossmember adds (has anybody with Savvy UA had this problem and experimented with and without the skid installed?). Since it has features placing opposing pressures on the resonant frequency, one is probably winning out and moving it in one direction or the other and none of us probably have the means to figure out exactly which way. If I had the resources, I would love to go for a drive with accelerometers on the skid plate, the transfer case housing, and the rear axle housing.
A 1/4" aluminum skid should reduce mass and increase rigidity, which might move the frequency up and out of range. A 3/16" steel skid would be the opposite and might move it down where the trigger frequency is less intense, but not sure where it would lie compared to a stock skid, which isn't particularly massive but has a lot of stiffening features.
