Back to this, I hate to keep blistering with questions, but you guys are awesome and im having trouble
I installed my compressor, no problems. Just need to wire it and plumb lines. I am trying to get a list to gather for what I need fittings/parts wise. I have heard that the threads on the intake/discharge are 1/2" NPT but I went to ace to get some fittings and they ended up being 3/4 so I'm not sure if mine is different or what. I am not going to be using an air tank or lockers. If you guys can tell me what I need/don't need i'd appreciate it, thanks.
Parts I need:
1/2" (3/4"?) -NPT elbows for York intake/discharge ports- am trying to find the ones that are shaped like a T or the ones that also screw into the york like so
Manifold block- what size, how big threads?
Oil water separator: ordered from ORO
Air cooler: Not required but I'm going to use a small power steering cooler
Pressure discharge/relieve valve, this one okay?
Air line: I got 12' of heater core hose (roughly 1/2-3/4" diameter) I think that will work-also will get hose clamps
Other fittings needed-not sure, ill buy them as I install
Cant seem to find a wiring kit for the york on ORO's website, Ill give Steve a call tomorrow
Parts I need:
