Airing Down
Most off road tires go back on the bead pretty easy. Usually the most it takes is a strap around the tire. Sand paddle tires can be a pain to get back on the bead.
I have been told starting fluid works well. Don’t use half a can and stand in front of it.
First trip to Moab have fun. Some trails I enjoy. Fins and things, top of the world, poison spyder.
I have reseated quite a few beads and have never used a strap. We just pull the bead into the wheel by hand and feet then inflate with the nearest air compressor.
Hopefully I'll need none of these methods but good to know when at 12-ish. Hunch is my trail buddies will refuse to go below 20#.. "internet forum bullshit".. 😂
Gonna be 2 LJR (32s & 35s, 2 JKUR (35s), and an XJ (31s) plus whatever the locals roll with.
So I air'd down to 20 psi, and went down a very rocky road to Skull Rock ( Google it )
I had a blast bouncing down the trail.
I'll never forget the bro dozer JKU I found myself airing up next to years ago. He proudly tells me he loves his CO2 tank, but he needs to refill it every other wheeling trip. I ask what he fills up to. 45psi, he proclaims. What do you air down to? 25psi, he proclaims.
I tell him my street pressure is 25psi and that I usually air down to 8psi. He goes silent, packs up and leaves.
This is a topic on which I learned a lot mountain biking. It’s controversial and there are many opinions on tire pressure in that world too.
A few good parallels that I note:
1. lower pressure increases traction.
2. higher volume tires need less pressure.
3. tires with beefier sidewalls need less pressure.
For mountain bikes, I lower pressure until they start to feel squirmy and add a couple of PSI back (usually 18-19 PSI front, 22-24 PSI rear with 29x2.5” tires)
For my 33x12.5x15 C range tires on a 3500# TJ, 23-24PSI street, 8-10 PSI trail
(no bead locks on the bikes or Jeep).
The strap is very helpful for tires with softer sidewalls that is a quick trick if the bead does not want to come up on the rim. Everyone Carries a tie down. Tire shops will have one that is inflatable.
I spend many years of recreation in the sand where sand gets in the bead and you loose the bead. I learned a few tricks along the way for stubborn beads.
They don’t put bead lock on mountain bikes?
Actually, you can. Same idea as Coyote inflatable bead locks you can get for a Jeep wheel. Mostly used for downhill bikes. Here’s a cross section of one (Schwalbe pro core, in this case):
I Figured my dirt bike has bead locks on it. I figured a mountain bike would. I can definitely see it on a downhill bike.
Reactions: Woodrow
when it comes to bikes, I have two basic rules
1) the bike must have a minimum of 1800cc's and 120Hp
and
2) the tires must NOT have a center groove —-like Dunflops. Metzlers are a much better tire in the rain and on steel deck bridges
and
I gave up sport bikes when my kids were born. Metzler comp K rubber was the best back then. I did get a wild hair and test ride a CBR1000RR a few years back. At the time, I think those bikes were around 160hp and close to 400#. I told myself I was going to take it easy but soon enough the front end was lifting in triple digits😃
Lucky for my family and me, I walked away, but so close to buying it on the spot.
Colorado LJ, pretty stock with no lockers or anything. KO2 33x10.5-15. Street 28PSI. Off-road 10. I have a co2 tank and only fill back up to 20 to drive home and fill up the rest of the way with my shop compressor. Never have had any problems. Very happy with my setup but I know my limits.
