The comments about tightening beadlock bolts every couple weeks is over hyped on the internet. What most fail to think about is beadlock wheels can weigh 10 pounds or more over a stock wheel. That rotational mass negatively impacts the Jeeps braking and acceleration. That said, I've run beadlocks on several Jeeps with zero issues.
My main reason for running them is the rocks where I wheel chew up the lips on stock wheels. While I've not lost a bead, I have had small rocks and sticks wedged in between the tire and wheel lip, and damaged wheels where the fix was to replace them. The beadlock rings do a fantastic job of protecting them from this happening.
How often would you need to check the tightness on the beadlock if not every 2 weeks? What beadlocks do you run and how low have you aired down with them on? Do you notice a pretty massive difference with beadlocks vs normal wheel/tires aired down?
