After the Savvy MUA, with JB SS SYE and rear Adam’s driveshaft, I get vibrations from the stock front DS at 65+mph. The vibes are only under load. I’ve fiddled with the pinion, it’s 0.5* higher than the DS. When I remove it, vibes go away. Should I change the u joints first? Anything else I should replace on that shaft? What if that doesn’t work? What would be next?
