Jeep Wrangler TJ Torque Specs (1997-2006)
Chris
Administrator
Staff Member
Gillette, WY
Battery - Charging System (1997 - 2006)
Component
Torque
Generator Upper Mounting Bolt 2.5/4.0L Engine
55 N-m (41 ft. lbs.)
Generator Lower Mounting Bolt 2.5L/4.0L Engine
Battery Terminal Nut
8.5 N-m (75 in. lbs.)
Ground Terminal Nut
Harness Hold-down Nut
Field Terminal Nuts
2.8 N-m (25 in. lbs.)
Body (1997 - 2006)
Component
Torque
Hood hinge screws
17 N-m (155 in. lbs.)
Bucket seat front anchor bolt
47 N-m (35 ft. lbs.)
Bucket seat rear inboard anchor bolt
74 N-m (55 ft. lbs.)
Bucket seat rear outboard anchor bolt
33 N-m (25 ft. lbs.)
Liftgate glass ball stud nut
12 N-m (112 in. lbs.)
Liftgate glass hinge nut
6 N-m (53 in. lbs.)
Liftgate hinge to hardtop bolt
10 N-m (95 in. lbs.)
Front turning loop bolt
Front retractor bolt
Rear retractor bolt
Rear turning loop bolt
Rear belt anchor bolt
Rearview mirror setscrew
1 N-m (9 in. lbs.)
Rear buckle anchor bolt
43 N-m (32 ft. lbs.)
Side support bar to sport bar bolts
71 N-m (53 ft. lbs.)
Sport bar to wheelhouse bolts
40 N-m (30 ft. lbs.)
Sport bar to cargo floor bolts
Sport bar to windshield frame bolts
32 N-m (24 ft. lbs.)
Tailgate hinge screws
23 N-m (200 in. lbs.)
Tailgate striker
71 N-m (52 ft. lbs.)
Brakes (1997 - 2006)
Component
Torque
Brake pedal support bolt
28 N-m (21 ft. lbs.)
Brake boost mounting nuts
37 N-m (27 ft. lbs.)
Master cylinder mounting nuts
24 N-m (18 ft. lbs.)
Master cylinder brake lines
15 N-m (11 ft. lbs.)
Combination valve mounting nuts
Combination valve brake lines
21 N-m (15 ft. lbs.)
Caliper mounting bolts
Caliper brake hose bolt
31 N-m (23 ft. lbs.)
Wheel cylinder mounting bolts
10 N-m (7 ft. lbs.)
Wheel cylinder brake line
16 N-m (12 ft. lbs.)
Parking brake lever bolts
12 N-m (9 ft. lbs.)
Parking brake lever bracket bolts
12 N-m (9 ft. lbs.)
Cable retainer nut
1.5 N-m (14 in. lb.s)
Brakes - Antilock (1997 - 2006)
Component
Torque
Acceleration Sensor Bolt
8-9 N-m (71-83 in. lbs.)
G-Sensor Bolt (2004)
4-5 N-m (35-45 in. lbs.)
Acceleration Sensor Bracket Bolt
1-2 N-m (13-18 in. lbs.)
Hydraulic Control Unit Mounting Bolts
20 N-m (177 in. lbs.)
Hydraulic Control Unit Bracket Mounting Bolts
4-9 N-m (35-76 in. lbs.)
Hydraulic Control Unit Body Bracket Bolts (2004)
16-24 N-m (142-212 in. lbs.)
Hydraulic Control Unit Brake Lines
16 N-m (144 in. lbs.)
Controller Antilock Brakes Mounting Bolts
8-13 N-m (75-115 in. lbs.)
Wheel Speed Sensor Front Mounting Bolt
4-6 N-m (34-50 in. lbs.)
Wheel Speed Sensor Rear Mounting Bolt
12-14 N-m (106-124 in. lbs.)
Clutch (1997 - 2006)
If you choose to replace your Wrangler's clutch yourself you will need these specs along witd tdose of the transfer case, transmission, and belly pan.
Component
Torque
Bolts, clutch cover 2.5L and 2.4L
Bolts, clutch cover 4.0L
52 N-m (38 ft. lbs.)
Nut, clutch master cylinder
38 N-m (28 ft. lbs.)
Nut, clutch slave cylinder
23 N-m (17 ft. lbs.)
Bolt, clutch housing M12
75 N-m (55 ft. lbs.)
Bolt, clutch housing 3/8
Bolt, clutch housing 7/16
58 N-m (43 ft. lbs.)
Bolt, clutch housing/trans
Bolt, dust shield lower
50 N-m (37 ft. lbs.)
Bolt, X-Member/frame
41 N-m (30 ft. lbs.)
Bolt, X-Member/rear support
45 N-m (33 ft. lbs.)
Bolts, flywheel 4.0L
142 N-m (105 ft. lbs.)
Bolts, flywheel 2.5L and 2.4L
68 N-m (50 ft. lbs. 1/4 turn)
Bolts, U-joints
19 N-m (170 in. lbs.)
Cooling System (1997 - 2006)
Component
Torque
Generator Pivot Bolt
Generator Rear Adjusting Bolt
27 N-m (20 ft. lbs.)
Auto Trans Auxillary Oil Cooler Mounting Bolts
2 N-m (18 in. lbs.)
Fan Blade-to-Viscous Fan Drive Bolts
3.7L Fan Blade Assembly to Viscous Drive Bolts (2004)
23 N-m (210 in. lbs.)
Viscous Fan Drive-to-Water Pump Nuts
Fan Shroud Screws (2.5L)
Fan Shroud Screws (4.0L)
4 N-m (31 in. lbs.)
Electric Fan to Fan Shroud Bolt (2004)
5 N-m (50 in. lbs.)
Engine Block Heater Fastener
4 N-m (31 in. lbs.)
Engine Block Heater Bolt (2004 2.4L)
2 N-m (17 in. lbs.)
Thermostat Housing Bolts
20 N-m (15 ft. lbs.)
Water Pump Bolts (2.5L and 4.0L)
30 N-m (22 ft. lbs.)
Water Pump Bolts (2004 4.0L)
Water Pump Bolts (2004 2.4L)
12 N-m (105 in. lbs.)
Automatic Belt Tensioner to Mounting Bracket (2004 2.4L)
Automatic Belt Tensioner Pulley Bolt (2004 2.4L)
61 N-m (45 ft. lbs.)
Coolant Overflow Bottle to Plenum Bolts (2004 2.4L)
Fan Shroud to Radiator Mounting Bolts (2004)
8 N-m (70 in. lbs.)
Radiator Upper Isolator to Crossmember Bolts (2004)
9.5 N-m (85 in. lbs.)
Thermostat Housing Bolts (2004 2.4L)
28 N-m (250 in. lbs.)
Differential and Driveline - Propeller Shafts & U-Joints (1997-2006)
Component
Torque
Front Shaft Transfer Case Yoke Bolts
Front Yoke Bolts (1998)
Axle Yoke Bolts (front and rear)
19 N-m (14 ft. lbs.)
Differential and Driveline - Front Axle (1997)
Component
Torque
Fill Hole Plug
34 N-m (25 ft. lbs.)
Differential Cover Bolt
Bearing Cap Bolt
Ring Gear Bolt
95-122 N-m (70-90 ft. lbs.)
Axle Nut
237 N-m (175 ft. lbs.)
Wheel Bearing Bolt
102 N-m (75 ft. lbs.)
Lower Ball Joint Stud
108 N-m (80 ft. lbs.)
Upper Ball Joint Stud
101 N-m (75 ft. lbs.)
ABS Sensor Bolt
11 N-m (96 in. lbs.)
Pinion Nut (Minimum)
17 N-m (160 in. lbs.)
Differential and Driveline - 181 FBI Axle (1998 - 2006)
Also called the Dana 30, the 181FBI is a front beam type axle. All TJ Wranglers other than Rubicon models came standard witd a Dana 30 front axle.
Component
Torque
Fill Hole Plug
Diff. Cover Bolt
Bearing Cap Bolt
Ring Gear Bolt
Axle Nut
Hub Bearing Bolt
Differential and Driveline - 216 RBI Rear Axle (1997)
These torque specs come in handy if you are changing differential fluid, rebuilding the axle, or regearing. these specs only apply for the front Dana 44 axle for TJ Wranglers. Dana 44 front axles came standard on Rubicon models, it was not available for any other models.
Component
Torque
Fill plug
Diff. cover bolts
Diff. Bearing Cap bolts
Ring gearbolts
Brake backing plate nuts
Pinion gear nut (minimum)
244 N-m (180 ft. lbs.)
Differential and Driveline - 216 RBI Rear Axle (1998-2006)
Component
Torque
Fill plug
Diff. cover bolts
Diff. bearing cap bolts
Ring gear bolts
217 N-m (160 ft. lbs.)
Differential and Driveline - 194 RBI Rear Axle (1997)
The 194 RBI is also called the Dana 35 and came standard in all TJ Wranglers other tdan the Rubicon.
Component
Torque
Diff. cover bolts
Ring gearbolts
292 N-m (215 ft. lbs.)
Note: Refer to pinion gear removal and installation procedures for proper pinion nut tightening instructions. Do not exceed 427 N-m (315 ft. lbs.) during collapsible spacer crushing procedure.
Differential and Driveline - 194 RBI Axle (1998-2006)
Component
Torque
Diff. cover bolts
Bearing cap bolts
77 N-m (57 ft. lbs.)
Pinion nut
271-474 N-m (200-350 ft. lbs.)
Pinion mate shaft lock screw
16.25 N-m (12 ft. lbs.)
Ring gearbolt
ABS sensor bolt
8 N-m (70 in. lbs.)
Emissions Control (1997-2006)
The evaporative emissions (Evap) system is used to prevent hydro-carbons from escaping into the atmosphere.
Component
Torque
EVAP canister mounting bolt
9 N-m (80 in. lbs.)
Leak detection pump (LDP) filter mounting bolts (1998)
7 N-m (65 in. lbs.)
LDP mounting screws (1998)
1 N-m (11 in. lbs.)
EVAP canister/LDP mounting bracket-to-body nuts (2004)
250 in. lbs.
EVAP canister/LDP mounting bracket-to-body bolts (2004)
212 in. lbs.
Engine - 2.5L (1997-2002)
The oxygen sensors require a special socket to be removed due to the wires. Also be sure to note that there are different specs for each set of bolts.
Component
Torque
A/C compressor bracket-to-engine bolts
A/C compressor mounting bolts
A/C low pressure service valve nut
Block heater nut
1.8 N-m (16 in. lbs.)
Camshaft sprocket bolt
Connecting rod nuts
45 Npm (33 ft. lbs.)
Converter plate bolts
68 N-m (50 ft. lbs.) at 60 degrees
Cylinder block drain plugs
Cylinder head bolts 1-10 & 12-14
149 N-m (110 ft. lbs.)
Cylinder head bolt 11
135 N-m (100 ft. lbs.)
Cylinder head cover bolts
10 N-m (85 in. lbs.)
Drive plate-to-torque converter bolts
54 N-m (40 ft. lbs.)
Engine shock damper stud nuts
Engine Mounts - Front
Cushion to black bracket nuts
69 N-m (51 ft. lbs.)
Cushion to frame bolts
Bracket to engine block screw
Bracket to engine block nut
Bracket to engine block stud
Engine Mounts - Rear
Trans cushion to crossmember nut
Trans bracket to skid plate nut
Trans mount to trans bracket nut
Trans bracket to trans
Exhaust manifold/pipe nuts
Flywheel/converter housing bolts
Flywheel/crankshaft bolts
143 N-m (105 ft. lbs.)
Front cover-to-block bolts 1/4-20
7 N-m (60 in. lbs.)
Front cover-to-block bolts 5/16-18
22 N-m (192 in. lbs.)
Fuel pump bolts
22 N-m (16 ft. lbs.)
Generator adjusting bolt
Generator pivot bolt/nut
Generator mounting bracket-to-engine bolts
Generator mounting/head bolts
Main bearing bolts
Oil filter
18 N-m (13 ft. lbs.)
Oil filter connector
Oil gallery plug
Oil pan1/4-20 bolts
9.5 N-m (84 in. lbs.)
Oil pan5/16-18 bolts
15 N-m (132 in. lbs.)
Oil pandrain plug
Oil pump short attaching bolts
Oil pump long attaching bolts
Oil pump cover bolts
8 N-m (70 in. lbs.)
Power steering pump pressure hose nut
Rocker arm assembly-to-cylinder head capscrews
Spark plugs
Starter motor mountingbolts
Thermostat housing bolts
Vibration damper bolts
Water pump/block bolts
31 N-m (270 in. lbs.)
Engine - 4.0L (1997-2006)
This engine is one of the most popular engines that Jeep has ever put into their vehicles. The torque specs needed to rebuild the inline six if the need should arise.
Component
Torque
Block heater nut
Connecting rod nuts
10 N-m (85 in. lbs.
Support bracket bolts
Support cushion bolts/nuts
Support cushion bracket bolts
Support cushion bracket stud nuts
Support cushion tdru-bolt
65 N-m (48 ft. lbs.)
Crossmember to sill bolts (automatics)
Insulator stud assembly nut
Support cushion crossmember nuts
Support cushion/bracket nuts (manuals)
Transmission support bracket bolt (manuals)
46 N-m (34 ft. lbs.)
Transmission support bracket/cushion bolt (4WD auto)
Transmission support adaptor bracket bolts (2WD auto)
7 N-m (60 in. lbs.)
Front cover-to-block 5/16-18
Fuel pump bolts
Main bearing bolts
Oil filter
Oil galley plug
Oil pan1/4-20 bolts
Oil pandrain plug
Oil pump attaching bolts
8 N-m (70 in. lbs.)
Spark plugs
Starting motor mounting bolts
Engine - 2.4L (2003-2006)
This engine was used from 2003 to 2006 and served as the successor to the 2.5 liter engine.
Component
Torque
Balance shaft carrier to block bolts
Balance shaft gear cover double ended fastener
Balance shaft sprocket bolt
Balance shaft chain tensioner bolts
Balance shaft carrier cover bolts
Connecting rod cap bolts
54 1/4 turn N-m (40 1/4 turn ft. lbs.)
Crankshaft main bearing cap/bedplate M8 bolts
34 N-m (250 in. lbs.)
Crankshaft main bearing cap/bedplate M11 bolts
41 1/4 turn N-m (30 1/4 turn ft. lbs.)
Crankshaft damper
136 N-m (100 ft. lbs.)
Flex plate to crankshaft
95 N-m (70 ft. lbs.)
Flywheel mounting bolts
81 N-m (60 ft. lbs.)
Right engine mount bracket bolts
Exhaust manifold to cylinder head bolts
Exhaust manifold heat shield bolts
Lower intake manifold bolts
Oil filter
Oil panbolts
12 N-m (150 in. lbs.)
Oil pandrain plug
Oil pump cover plate bolts
12 n-m (105 in. lbs.)
Oil pump pickup tube bolts
28 N-m (20 ft. lbs.)
Oil pump relief valve cap
Spark plugs
Timing belt front cover to rear cover bolts
Timing belt rear cover bolts
Timing belt tensioner assembly bolts
Exhaust & Intake Manifolds (1997-2006)
The oxygen sensors require a special socket to be removed due to the wires. Also be sure to note that these are different specs for each set of bolts.
Component
Torque
Exhaust pipe to manifold nuts
Exhaust manifold 2.5L engine bolts #2-5
Exhaustmanifold 2.5L engine nuts #6-7
Exhaust manifold 4.0L engine nuts/bolts #1-5 & #8-11
33 N-m (24 ft. lbs.)
Exhaust manifold 4.0lL engine nuts #6-7
Intake manifold 2.5L engine bolt #1
Intake manifold 2.5L engine bolts #2-5
Muffler to catalytic converter clamp nut
48 N-m (35 ft. lbs.)
Oxygen sensors
Frame and Bumpers (1997-2006)
There will be six bolts for the front bumper. Four on top and two underneath. On the rear bumper, there are two nuts that need to be removed from each side and two bolts going into the bottom side of the frame.
Components
Torque
Front bumper screw
104 N-m (77 ft. lbs.)
Front bumper scew (2004)
Front tow hook screw
Front tow eye screw
Fuel tank skid plate nuts
16 N-m (138 in. lbs.)
Fuel tank strap nuts
5 N-m (40 in. lbs.)
Radiator to frame hold down bolt (2004)
60 N-m (45 ft. lbs.)
Rear bumper bolt
67 N-m (50 ft. lbs.)
Rear bumper bolt (2004)
Rear bumper nut
Rear tow eye screw
47 n-m (35 ft. lbs.)
Rear tow hook screw (2004)
Transfer case skid plate bolts
Transmission mount nuts
Transmission mount nuts (2004)
35 N-m (26 ft. lbs.)
Transmission skid plate to frame bolts (2004)
Transmission skid plate to transfer case skid plate (2004)
Fuel System (1997-2006)
Use caution when servicing any part of the fuel system. Wear safety glasses to prevent eye exposure. If gasoline gets into your eyes immediately flush them with water for 15 minutes. If irritation persists call a doctor.
Component
Torque
Accelerator pedal bracket mounting nuts
Fuel pump module locknut
Fuel pump module locknut (1998)
62 N-m (45 ft. lbs.)
Fuel rail mounting bolts or nuts
11 N-m (100 in. lbs.)
Fuel tank skidplate bolts
16 N-m (141 in. lbs.)
Fuel tank mounting strap bolts
5 N-m (40 in. lbs.)
Engine coolant temperature sensor
Fuel hoseclamps
1 N-m (10 in. lbs.)
Fuel hoseclamps (1998)
3 N-m (25 in. lbs.)
IAC motor-to-tdrottle body bolts
7 N-m (60 in. lbs.)
Intake manifold air temp sensor
MAP sensor mounting screws
3 N-m (25 in. lbs.)
Oxygen sensor
PCM mounting screws
4 N-m (35 in. lbs.)
Power steering pressure switch
28 N-m (252 in. lbs.)
tdrottle body mounting bolts
12 N-m (108 in. lbs.)
tdrottle position sensor mounting screws
7 N-m (60 in. lbs.)
Vehicle speed sensor mounting bolt
2.2 N-m (20 in. lbs.)
Ignition System (1997-2006)
Component
Torque
Crankshaft position sensor bolts witd manual transmission
Crankshaft position sensor nuts - 2.5L w/ auto trans
Crankshaft position sensor bolt - 4.0L w/ auto trans
7 N-m (60 in. lbs.)
Distributor hold down bolt
Distributor cap screws
3 N-m (26 in. lbs.)
Ignition coil mounting (if tapped bolts are used)
5 N-m (50 in. lbs.)
Ignition coil mounting (if nuts/bolts are used)
Spark plugs (all engines)
Steering (1997-2006)
Component
Torque
Power steering pump bracket to pump
Power steering pump bracket to engine
Power steering pump flow control valve
Power steering pump pressure line
Tilt steering column steering wheel nut
Tilt steering column mounting nuts
Tilt steering column coupler bolt
49 N-m (36 ft. lbs.)
Non-tilt steering column steering wheel nut
Non-tilt steering column mounting nuts
Non-tilt steering column coupler bolt
Non-tilt steering column upper bracket nut
17 N-m (150 in. lbs.
Steering Linkage (1997-2006)
If you do any work on your steering or suspension it is a good policy to re-torque your steering components. With something like your steering linkage, you want to be sure everything is tight or else you could experience some vibrations.
Component
Torque
Pitman arm shaft
251 N-m (185 ft. lbs.)
Drag link ball studs
Drag link clamp
Tie rod ends - ball studs
Tie rod ends - clamp
Tie rod puller ball stud
88 N-m (65 ft. lbs.)
Steering damper - frame
Steering damper - drag link
74 n-m (55 ft. lbs.)
Power Steering (1997-2006)
The power steering system in TJ wranglers changed after in 2003. Wranglers from 1997-2002 use power steering fluid, 2003-2006 use ATF 4. These fluids should not be mixed, be sure to check your owners manual for all recommended fluid types.
Component
Torque
Adjustment cap locknut
Adjustment screw locknut
Gear to frame bolts
Pitman shaft nut
Rack piston plug
Side cover bolts
60 N-m (44 ft. lbs.)
Pressure line
Return line
Steering - Manual Steering (1997-2006)
The specs for manual and power are different so be sure to use the correct specs.
Component
Torque
Adjustment Cap Locknut
Adjustment Screw Locknut
Pitman Shaft Nut
Guide Clamp Screws
14 N-m (10 ft. lbs.)
Cover Bolts
Gear to Frame Bolts
105 N-m (78 ft. lbs.)
Suspension - Front (1997-2006)
Component
Torque
Upper Shock Absorber Nut
Lower Shock Absorber Nut
Suspension Arm Lower
Axle Bracket Nut
115 N-m (85 ft. lbs.)
Axle Bracket Nut (2003)
163 N-m (120 ft. lbs.)
Axle Bracket Nut (2004)
176 N-m (130 ft. lbs.)
Frame Bracket Nut
Suspension Arm Upper
Axle Bracket Nut
Frame Bracket Bolt
Frame Bracket Bolt (2004)
Stabilizer Bar
Retainer Bolts
Retainer Bolts (2004)
Link Upper Nut
Link Lower Bolt
Link Lower Bolt (2004)
Track Bar
Ball Stud Nut
Ball Stud Nut (2004)
Axle Bracket Bolt
Axle Bracket Bolt (2004)
Hub/Bearing (1998)
Bolts
Axle Nut
Suspension - Rear (1997-2006)
Component
Torque
Upper Shock Absorber Bolts
100 N-m (74 ft. lbs.)
Axle Bracket Nut
177 N-m (130 ft. lbs.)
Frame Bracket Nut
Axle Bracket Nut
Frame Bracket Bolt
Stabilizer Bar
Retainer Bolts
Link Nut/Bolt
Track Bar
Frame Bracket Nut
Axle Bracket Bolt
NOTE: Refer to Pinion Gear Removal and installation procedures for proper pinion nut tightening instructions. Do not exceed 352 N-m (260 ft. lbs.) during collapsible spacer crushing procedure.
Component
Torque
Access plugs
Adapter Housing Bolts
Back-up Light Switch
44 N-m (32.5 ft. lbs.)
Drain and Fill Plugs
Front Bearing Retainer Bolts
17 N-m (12 ft. lbs.)
Interlock and Detent Plugs
Propeller Shaft Clamp Screws
16-23 N-m (140-200 in. lbs.)
Rear Mount toTransmission Bolts
33-60 N-m (24-44 ft. lbs.)
Rear Mount Clevis Nut
54-75 N-m (40-55 ft. lbs.)
Rear Mount toCrossmember Nuts
33-49 N-m (24-36 ft. lbs.)
Restrictor Pins
27.4 N-m (20 ft. lbs.)
Reverse Shift Arm Bracket Bolts
Shift Arm Set Screws
Shift Fork Set Screws
Shift Knob Nut
20-34 N-m (15-25 ft. lbs.)
Shifter Floor Cover Screws
2-3 N-m (17-30 in. lbs.)
Shift Tower Bolts
Transfer Case Mounting Nuts
30-41 N-m (22-30 ft. lbs.)
Transmission & Transfer Case - AX15 Manual (1997 - 1999)
Component
Torque
Access Plugs
Interlock andDetent Plugs
Rear Mount to Transmission Bolts
Rear Mount to Crossmember Nuts
Restrictor Pins
Shift Arm Set Screw
Shift Knob Nut
Shift Tower Bolts
Transmission & Transfer Case - NV1500 Manual (2003-2004)
Component
Torque
Back Up Lamp Switch
Countershaft Bearing Shim Cap
Bearing Retainer - Front
Bearing Retainer - Rear
Drain/Fill Plug
Shift Shaft Lock Bolt
Idler Shaft Bolts - M8
Idler Shaft Bolts - M10
52 N-m (40 ft. lbs.)
Shift Tower Bolts 11
8 N-m (100 in. lbs.)
Clutch Housing Bolts
Transmission Bolts
Skid Plate Bolts
41 n-m (31 ft. lbs.)
TransmissionMount Bolts
Transmission & Transfer Case - NV3550 Manual (2000 - 2004)
Component
Torque
54-61 N-m (40-45 ft. lbs.)
Crossmember to Frame Bolts
61-75 N-m (44-55 ft. lbs.)
Crossmember to Insulator Nuts
Drain/Fill Plug
9-27 N-m (14-20 ft. lbs.)
Front to Rear Housing Bolts
30-35 N-m (22-26 ft. lbs.)
19-25 N-m (14-18 ft. lbs.)
Idler Shaft Bolts
Rear Bearing Retainer Bolts
Shift Tower Bolts
7-10 N-m (5-7 ft. lbs.)
Slave Cylinder Nuts
Transfer Case Nuts
U-Joint Clamp Bolts
Transmission & Transfer Case - NSG370 Manual (2005 - 2006)
Component
Torque
Drain Plug
Fill Plug
Shift Tower Bolts
10 N-m (7 ft. lbs.)
Housing Bolts
Input Shaft Retainer Bolts
9 N-m (80 in. lbs.)
10 N-m (88 in. lbs.)
Shift Rail Support Bolts
8 N-m (71 in. lbs.)
Idler Gear Shaft Bolt
Countershaft Bolt
Transmission Mounting Bolts 2.4L
Dust Shield 2.4L
Transmission Mounting Bolts 4.0L
Dust Shield 4.0L
Transmission & Transfer Case - 30/32RH Automatic (1997-2002)
Component
Torque
Torque Convertor Bolt
Crossmember Bolt/Nut
Driveplate to Crankshaft Bolt
Front Band Reaction Plug
17 N-m (13 ft. lbs.)
Front Band Adj Locknut
Park/Neutral Switch
43 N-m (25 ft. lbs.)
Fluid Pan Bolt
Oil Pump Bolt
Overrunning Clutch Cam Bolt
Pressure Test Port Plug
Reaction Shaft Support Bolt
20 N-m (15ft. lbs.)
Rear Band Locknut
Speedometer Adapter Bolt
11 N-m (8 ft. lbs.)
Fluid Filter Screw
4 N-m (35 in. lbs.)
Valve Body to Case Bolt
12 N-m (100 in. lbs.)
Transmission & Transfer Case - 42RLE Automatic (2003-2006)
Component
Torque
Converter to Driveplate Bolt
Fluid Filter to Valve Body Bolt
5 N-m (45 in. lbs.)
L/R Clutch Retainer to Case Bolt
5 N-m (45 in. lbs.)
Adapter/Extension Housing Bolt
Manual Valve Lever to Manual Valve Bolt
5 N-m (45 in. lbs.)
Oil Pan to Case Bolt
20 N-m (14.5 ft. lbs.)
Oil Pump to Case Bolt
30 N-m (265 in. lbs.)
Park Sprag Retainer Bolt
4.5 N-m (40 in. lbs.)
Reaction Shaft Support Halves Bolt
Solenoid/Pressure Switch Assy to Valve Body Bolt
5.5 N-m (50 in. lbs.)
Valve Body to Transfer Plate Bolt
5 N-m (45 in. lbs.)
Cooler Line Fitting
47.5 N-m (35 ft. lbs.)
Output Shaft Nut
271 N-m (200 ft. lbs.)
Pressure Tap Plug
5 N-m (45 in. lbs.)
Input Speed to Case Sensor Bolt
9 N-m (80 in. lbs.)
Output Speed to Case Sensor Bolt
9 N-m (80 in. lbs.)
Transmission & Transfer Case - NV231 Transfer Case (1997-2006)
The NV231 is also commonly referred to as Command-Trac. It is a shift-on-the-fly part time 4WD transfer case. This transfer case has a 2.72-1 gear ratio in 4-Low.
Component
Torque
Detent Plug
16-24 N-m (12-18 ft. lbs.)
Drain/Fill Plug
20-34 N-m (15-20 ft. lbs.)
35-46 N-m (26-34 ft. lbs.)
21 N-m (16 ft. lbs.)
Case Half Bolt
27-34 N-m (20-25 ft. lbs.)
Front Yoke Nut
122-176 N-m (90-130 ft. lbs.)
Range Lever Nut
27-34 (20-25 ft. lbs.)
Rear Retainer Bolt
Mounting Nuts
29-40 N-m (22-30 ft. lbs.)
Indicator Switch
Transmission & Transfer Case - NV241 Transfer Case (2003 - 2006)
The NV241 is a shift-on-the-fly part time 4WD transfer case. This transfer case has a 4-1 gear ratio in 4-Low.
Component
Torque
Detent Plug
16-25 N-m (12-18 ft. lbs.)
Drain/Fill Plug
Rear Extension Bolt
Front Input Retainer Bolt
Case Half Bolt
20-27 N-m (15-20 ft. lbs.)
Front Yoke Nut
Rear Companion Flange Nut
258-312 N-m (190-230 ft. lbs.)
Shift Lever Bolt
Mounting Nuts
30-41 N-m (20-30 ft. lbs.)
U-Joint Bolt
19 N-m (17 ft. lbs.)
Sector Support
27-42 N-m (20-30 ft. lbs.)
Transfer Case Position Sensor
20-34 N-m (16-25 ft. lbs.)
Speed Sensor Bolt
11-16 N-m (8-12 ft. lbs.)
Tires and Wheels (1997 - 2006)
Component
Torque
Lug Nut 1/2x20 with 60 degree cone
115 - 156 N-m (85 - 115 ft. lbs.)
Looking for torque spec. for the water pump pulley and belt tensioner.
I see fan blades to viscous fan, the viscous fan to the water pump and the water pump itself, but I do not see the torque spec. for the 4 small bolts attaching the water pump pulley to the water pump.
Also, I don't see the belt tensioner for 2002 4.0L.
Any help appreciated.
I could not find the torque spec for the bolts in the rear drive shaft flange that mounts to the 241 TC in a TJ Rubicon. Anyone? I think the spec for the strap bolts on the rear universal is 17 ft-lbs. Correct?
I thought it was 14 at the U-joint and 85 at the flange.
I think @JMT posted torque specs etc for a lift installation, in a thread. Can anyone point me which thread was that, since I cannot find it anymore?
They're all in this stickie. I may have given the values for someone's specific lift in the past, but since the components one may need to install for various lift heights varies, there's no one set of torque specs fits all documents I know of besides sorting it out from this stickie.
Reactions: TJim
ok! thanks. I was trying to be lazy! haha . but this stickie is golden
What is the difference between "Water pump bolts" vs "water pump/block" bolts? One is listed as 270 in.lb, the other is 200 in.lb. but the both sound like they are for installing the water pump...
Found the answer to my question in the Service Manual. Water pump mounting bolts call for 200 in.lb.
Note: I went through the service manual (1998 at least) and the cylinder head (valve) cover bolt torques were listed at 85 in-lbs for the 4.0, not 115 as listed here. the 2.5 was listed at 115 in-lbs.
FYI
FYI
Reactions: roosterdrs
What's the torque value for anchor bolts on rear seat brackets for an '06, guys? I can't seem to find that value ANYWHERE?
Looking for the torque specs for the ignition coil rail bolts? There is a an allotment for a coil pack at 5Nm. I don’t think that is correct for the coil pack rail on the newer 4.0’s.
Can’t find them in the above torque specs. I have heard 25 ft lbs.
Anyone have the U Joint Strap Torque specs for the rear axle?
Do you add Loctite on those also...?
Can anyone confirm that under Steering Linkage in the table above, when it refers to “Drag Link Ball Studs 55 ft lbs” that is both ends? Ie where the drag link attaches to the Tie Rod and where it attaches to the Pitman Arm.
Yes
Reactions: UKTJ
