I know there's been threads about shock torque. But they didn't address this question. I'm mainly curious about the accuracy and appropriateness of these numbers, even if they are OEM specs I know that mistakes can be made and there's no errata published. Curious if there's better "real world" guidance from actual mechanics out there, or any info.
Front Upper: 23 N-m / 17 ft-lb
Front Lower: 28 N-m / 250 in-lb (inch-lbs... why? It's 21 ft-lbs but I'm curious why they'd list this one as inch-pounds when all others are ft-lbs)
Rear Upper - 23 ft-lb
Rear Lower: 74 ft-lb (this seems very high, but it's a bigger bolt than the rest so maybe? But this seems like a potential error)
Any advice here? Also, I don't see how I can ever get 17 ft-lbs onto the front upper without destroying the (brand new) bushings.
