U-joint torque
notnsuv
NOW I Know!
Spring Creek, NV
ComponentTorque
Front Yoke Bolts (1998)41 N-m (30 ft. lbs.)
2006 TJUR front driveline u-joint.
Sound correct? Didn't find it in the sticky.
14 ft-lbs. for the small strap bolts. Knock that down to 12 ft-lbs. if you are applying blue Loctite to the threads as should be done. Personally I use a small 8mm combination wrench or 1/4" ratchet wrench and just get it good and tight with my hand with the torque wrench left in the box.
Thanks.
Personally I use a small 8mm combination wrench or 1/4" ratchet wrench and just get it good and tight with my hand.
My usual also, but just checking for the guesstimate.
Reactions: Jerry Bransford
