It’s $358. Does it give more clearance in that location? I found nothing in the website saying I get more clearance there.Savvy?
I would say Savvy if you are ok with waiting 2 months. Apparently it’s one of the few that comes with new redesigned straps that allow for the most clearanceThat’s what I’m thinking. Which one do you think? I need the clearance higher up on the front of the gas tank skid. Rokmen is only $249.
Trust me, I thought about it.How about a BFH to the stocker? Clearance that bitch?
Next question is even if you clear the tank, will you clear the crossmemberHow much clearance do you need?
Hmm...if only there was a way to eliminate the TB...
Show me where you want me to measure...It’s $358. Does it give more clearance in that location? I found nothing in the website saying I get more clearance there.
Yeah, mid-arm my walletHmm...if only there was a way to eliminate the TB...
Distance from front center of crossmember to the Savvy gas tank skid.Show me where you want me to measure...
It’s doing something very similar to this, but it’s hitting on the passenger side rather than driver.
The distance from the front edge of the crossmember to the front of the savvy skid. It’s rubbing most of the way up the skid, then it gets bad where the yellow circle is. Thanks!Show me where you want me to measure...
Yeah, I don’t think so. I think my solution has two or three parts. Is there an alternate crossmember for our TJ’s?Next question is even if you clear the tank, will you clear the crossmember
Uh, yeah, @bobthetj03, but he eventually CAVED in to a small butt crackPersonally the mid arm doesn’t work for me, the butt crack would drive me insane...I’m sure there are others that feel that way.
