That’s what I’m thinking. Which one do you think? I need the clearance higher up on the front of the gas tank skid. Rokmen is only $249.
I would say Savvy if you are ok with waiting 2 months. Apparently it’s one of the few that comes with new redesigned straps that allow for the most clearance
Reactions: IPerkWVU
How about a BFH to the stocker? Clearance that bitch?
Trust me, I thought about it.
I think I’d have to drop the tank find a new place to bolt it up to the crossmember.
Does it contact the tank straps at full droop on the drivers side?
Show me where you want me to measure...
The distance from the front edge of the crossmember to the front of the savvy skid. It’s rubbing most of the way up the skid, then it gets bad where the yellow circle is. Thanks!
Next question is even if you clear the tank, will you clear the crossmember
Yeah, I don’t think so. I think my solution has two or three parts. Is there an alternate crossmember for our TJ’s?
