On-board air system ideas and suggestions?
The more shit you have to bolt on your rig to go offroading for an afternoon the less likely you'll be to do it. Being that it isn't a super expensive compressor I'd mount it permanently to your Jeep then get a second one if you want to haul around in your second vehicle.
The easier it is for you to hit the trails the more you'll be willing to do so. To me that means having my tool bag strapped down to a footman loop in the back of the jeep and my recovery gear at hand all the time. Now I've got my air compressor permanently mounted and an air hose sits behind the passenger seat (takes a lot less space than the portable compressor did). None of this impedes my daily driving duties (when I DD the Jeep) and I don't have to load anything extra if I'm going offroad. Means a Sunday drive into the forest at a moments notice is no problem at all and I'm as prepared as I'm going to be on any given moment (minus chains, I don't haul them around unless I'm headed to the snow).
Yeah. You're right. I will finish the project with the intention to be able to unmount it easily, and will see in the future if and how often I will actually unmount it.
Reactions: xxdabroxx
My Viair 400p automatically shuts itself off. It was designed that way, internal pressure switch.
Didn't realize that the 400 had that from the factory.
From VIAIR's website:
400P-Automatic is VIAIR’s first Automatic shut-off function powerful portable tire inflator. This 33% duty cycle unit is capable of pressures up to 150 PSI and can be operated for up to 40 minutes at a time before needing to be rested (at up to 40 PSI). The 400P-Automatic comes with a close-ended gas station-style air gun for added convenience.
Portable compressors with automatic shutoff come into play when moving from tire to tire, and when checking tire pressure in the middle of a tire fill. A typical portable compressor must be turned off between tire fills, and anytime you want to check tire pressure. If you aren’t near the compressor, this can turn into running laps back and forth to the portable compressor to turn the unit on and off. Automatic portables do not work in this fashion and will save you time & effort to get tires inflated quickly.
Great minds think alike.
Reactions: TJim and Apparition
Have you done this?
Yes. Repeatedly. As a conscious effort to measure pressures under various conditions under controlled circumstances. Took notes.
But didn't wear a lab coat if that matters. ;)
Makes so little sense I can't really wrap my head around it. You are seriously recommending somebody repeatedly, intentionally ramps up their compressor to max pressure instead of installing a switch or simply shutting it off. Strange advice, I've never heard anything like this before.
No, I'm saying that in my experiment hose pressure doesn't even get close to maximum output pressure of a Viair 400 series compressor and 25' 1/4" hose when moving from tire to tire with a closed chuck. That's even when dilly dallying on purpose.
I'm saying that one will hear the compressor start to work harder long before it gets to maximum pressure which should be enough of a reminder to the reasonable person to stop dilly dallying and put the closed chuck on the next tire without the need for a pressure switch to do it for them.
I'm also saying that a pop-off valve is a far simpler and direct means than a pressure switch to prevent any adverse effects that could ensue in the event excess pressure is allowed to build in the air hose during the time it takes to move a closed chuck air hose between tires, even if that time is excessive.
Edit: This was after I originally said that using an open flow air chuck rather than a closed chuck on a tankless system allows for the simplest system of all, with no pressure switch or pop-off valve. I even supplied a link.
YMMV
BTW, you can use the pop-off valve in your onboard air system as an emergency "no kneeling tire deflator" when you realize that you left your fancy new [ARB/Currie/Coyote/Fill in the Blank] deflators at home on the kitchen counter.
Just hook up an air hose and pull the ring. Not the best, but better than nothing. Turn on the compressor if you let out too much air.
BTDT :(
BTDT :(
I keep a valve core tool with spares in the center console. Probably don't need it as much any more now that I have a fancy deflator tool but they are handy if you take the cores out to air down. Those things are known to go flying at the least opportune time. I've never had the confidence but I've see people walk around and pull each core out of their tires then reinstall them in the same order at the dunes. My luck I'd be too slow and have 3 completely flat tires and 1 that is just right.
Use Currie's or ARB's deflator tool and never have another problem with lost cores.
I carry spare valve cores too.
You missed the "no kneeling" part. At the time there was something quite appealing about clipping on an air chuck and pulling a ring while standing upright. ;)
I've never been able to pull valve cores without kneeling or bending over longer than my tired old bones would prefer.
15+ years ago I was given a set of these for my birthday...
I set them for 13 psi and use them when ever I go off roading and tires require deflating.
One of the better birthday presents I received to use with my Jeep.
Just remove the cap from the tire stem, screw on the Staun Deflator and then remove them once the air hissing has stopped.
Reactions: Ephry73
. . . 15+ years ago I was given a set of these for my birthday . . . One of the better birthday presents I received to use with my Jeep. . . Just remove the cap from the tire stem, screw on the Staun Deflator and then remove them once the air hissing has stopped.
Even better than Staun's are the improved version from Coyote Enterprises, which coincidentally is the U.S. distributor for Staun deflators, but that is a subject for another thread.
https://www.coyoteents.com/deflators/
