@TJim,
I think you are making the project far too complicated.
You don't need pressure switches, etc. if you plumb a simple system.
It is also unrealistic to think that you will be using your compressor as a portable unit once you go to the trouble of hard mounting it. Just buy a longer hose such as the Flexzilla 25' x 1/4" version, shown here with my Viair 400P portable unit:
Here is a simple onboard system that does everything one needs to fill tires, etc. (It does not store air for ARB air lockers or an air horn but it doesn't need to.) Note that the output fitting is a male swivel, not the usual female fitting, because the system is plumbed just like a portable system, i.e. with an open chuck.
Here is close up of the compressor head with brass fittings and a Viair check valve:
See this link:
https://wranglertjforum.com/threads/how-to-simple-onboard-air-for-your-tj-lj-viair-400h.10235/
My system uses a check valve at the compressor head even though it is an open system. Although unnecessary in an open flow system, one benefit of a check valve is there will never be pressure on the piston or valves on initial start up which will draw fewer amps than if starting under pressure. A check valve will also isolate things that need to be under pressure from things that do not and is better designed for that purpose that the piston rings and valve ports of a compressor. Check valves are less than $15 on Amazon.
If you simply must run a closed chuck on the end of your air hose, you could install a "tee" and inline pop-off valve to blow off pressure if it takes too long moving from tire to tire. 85-100 psi would be good pre-set pressures for that. However, my experiments with a Viair 400P compressor suggest that there is plenty of time to move from tire to tire with a closed chuck without blowing up a 25' hose (typically rated to 300 psi) or harming the compressor (maximum working pressure of Viair 400 series compressors is 150 psi), particularly if one uses a check valve at the compressor head.
Here, you can see a pop-off valve in a testing manifold I made from leftover brass parts:
As far as wiring is concerned, I used a Blue Sea P/N 5024 battery top fuse block, 10 ga. wire and a 40 amp fuse. Since my compressor is wired directly to the battery, the wire run is short and there is a built-in switch in the Viair 400H compressor, no relay is necessary for my system. You will want to use a relay or constant duty solenoid if you locate the switch inside the cab.
For an open flow system the wiring schematic in post #10 should work just fine.
I have used this wiring diagram for many years, originally published by Currie Enterprises in the 1990's when Currie was marketing 12v onboard air systems:
Notes:
An "unloader" performs the same function as a check valve but with the added feature of bleeding off pressure from the compressor cylinder head when the compressor stops pumping. A standard check valve is sufficient, such as the check valves marketed by Viair.
A pressure switch is unnecessary and serves no practical function unless you are using an air tank and need the compressor to turn "on" when tank pressure drops below a certain level and turn "off" when it reaches a certain higher level. A compressor pressure switch is not practical to set tire inflation pressures. Use an air gauge or specialized inflator tool for that.
A pop-off valve could be plumbed into the system at the manifold where the pressure gauge is shown. The pressure gauge is only useful in a closed system with air tank and would be omitted in an open system.
