T
TexasTJ2K
Guest
I have a 2000 TJ, 4.0L, 5spd with the check engine light on. Sometimes, it will start blinking for a short time then return to solid again. Here are the codes I'm throwing:
P0205
P0300
P0303
P0305
So far, I've done the following: all new spark plugs, coil pack, cam shaft position sensor, and crank shaft position sensor. They've helped with the misfires but not gotten rid of them.
Also, there's an issue that I'm sure is being caused by these codes, but when the engine reaches operating temperature around 210, my engine will cut out after 3,000rpm. If I upshift it will start again, but when I hit 3k rpms the engine won't respond to anything. It doesn't shut off, but pumping the gas causes nothing and I am forced to shift.
Any help is greatly appreciated. Next up, I'm going to move around some of the injectors to see if the issue follows the injector or if it's something else. I was also told by a buddy who helps me with repairs that it could be the head gasket.
Thank you.
P0205
P0300
P0303
P0305
Thank you.
