There should never be crow to eat when troubleshooting. Everyone pitches in with constructive thinking until it’s solved. Egos get in the way when team troubleshooting.
Egos and logic can both get in the way, I suppose.
Just confirmed, using the same troubleshooting as the video, tps is good.
That crossed my mind too. Is there a way to test that?
Ok. Now test the map sensor.
-Key on, engine off: Backprobe pink/yellow wire. Should be 5 volts.
- Key on, engine off: Install back probe in signal wire (VIO/BRN) unplug sensor, should jump to 5 volts.
- Incandescent test light connected to battery positive, touch ground wire DK BLU/DK GRN. Test light should light.
- Plug sensor back in. Clear codes.
- Back probe the signal wire again. Start vehicle. Map sensor signal voltage should read below 2 volts at idle and above 3.5 volts with the pedal to the floor.
Edit: also, now that we’re dealing with MAP, make darn sure your throttle body is cleaned. Too many times I’ve seen where MAP related faults are because of carbon build up. Vacuum leaks are also something to keep in mind, however, the fuel trims you posted, although maybe a little high, don’t suggest a huge vacuum leak. You also don’t have lean codes, so I wouldn’t focus on that too hard right now.
Your scan tool should have a function called freeze frame data when you click on the trouble code. It’s a picture of all of the OBD2 data as it was the moment the PCM triggered a DTC. It allows a trained eye to see why the DTC was set and can be a real aid in troubleshooting intermittent faults.
Well that didn’t take long, see the attached pictures. View attachment 623007View attachment 623008View attachment 623009
Well according to this chart you'd need to be at 15000 ft for 15.1 inHg.
https://www.sensorsone.com/altitude-pressure-units-conversion/
-Mac
This is the frustrating part with "troubleshooting" when you only have access to OBD2 data. OBD2 is the minimum data that was required by the government for that year of vehicle. OEM data is much more in depth. The troubleshooting charts (attached) provided by Jeep assume that you have access to OEM data via the DRBIII. Many aftermarket scan tools have access to this same data. I believe your scanner does not.
For instance, in your case Jeep's troubleshooting tree has you looking at live data of the TPS and Map voltages on the scan tool. This particular DTC is upset with the fact that TPS and MAP signal return voltages are out of range at certain throttle positions. Your OBD2 data, or at least what you posted, is giving us inHG and Load %, instead of Map voltage and TPS voltage. I'm sure some guru out there has a chart or something that would be able to convert these values to voltages, but I'm not that guru.
Long story short, this is where a quality scan tool comes into play. It's one thing to backprobe and measure voltages at sensors. Many times we can catch a sensor acting stupid with these tests. But when those methods check out just fine, it requires looking into the PCM. Unless you've verified that the PCM is receiving and translating these signals properly with the use of OEM live data, it's almost impossible to truly "troubleshoot" the issue.
Post the rest of the pages of data just in case so we can see if Map and TPS voltages are listed.
The scan tool is counting a line item not pages. So there are 12 lines of data.
