Hot Transmission?
You don’t need a temp gauge and sensor on a manual transmission. If you remove the console and look at the lower shift boot it may be torn. That’s the number one way excess heat enters from that area. Replace the boot and add any additional heat blocking insulation and it will lower the in cab temps.
So when we lift the body soon to swap the motor, this boot will be right there?
It’s on the inside of the tub under the console just under your shifter in front of the cup holder.
Reactions: Rustee
Thank you. Do you know where I can get the heat barrier material?
There are some great threads on here for sound deadening and heat barrier. External on the transmission “tunnel” is always best if you can swing it. When you look under the rig, you’ll see some heat barrier insulation in various places. That’s really good stuff. Don’t lose that. Something like that is really good. Check Summit. Wish I could be more specific.
Reactions: Rustee
There are some great threads on here for sound deadening and heat barrier. External on the transmission is always best if you can swing it. When you look under the rig, you’ll see some heat barrier insulation in various places. That’s really good stuff. Don’t lose that. Something like that is really good. Check Summit. Wish I could be more specific.
Okay got it but when you say "external" on the transmission...what do you mean by that exactly? I know it means outside the transmission but does it mean on the transmission rather than the body?
My bad. I meant to say on the transmission tunnel!
Reactions: Rustee
Reactions: Rustee
This
sometimes a torn/ disintegrated inner boot can let heat in
Having said that the transmission tunnel gets hot to the touch even when everything is up to par. Additionally you can check/change the fluid
Having said that the transmission tunnel gets hot to the touch even when everything is up to par. Additionally you can check/change the fluid.
I checked this today and it looked pretty destroyed lol
