Range is always the question. In this case though, my question is how long could this set up do rock crawling type trails on a single charge? If it could do the Rubicon with charge to spare, that would be interesting.
100% agree, but perhaps not for the same reasons. Range for me is, the ONLY thing that isn't as extraordinarily better in an all EV Jeep conversion.
Do I wish I could get the approximately 180 miles that a 18gal gas tank could ferry me (on a GOOD day, 13mpg x 18gal = 234 miles - wishful thinking...) - yes I do.
But, right now, I'm getting 2.4mi/kW and I have a 38.8 kW Pack (the Pack, as confusing as this might sound, is all the battery modules in the vehicle OR the individual battery module, which is made up of a bunch of individual cells or pouches - so confusing...sorry).
So, right now, we have a 38.8kW Pack x 2.4mi/kW = 93.12 mile range WITHOUT regen.
But, we have regen! (regen is when you take your foot off the throttle pedal and let the inertia of the vehicle reverse the motor and turn it into an instant alternator that charges back the Pack).
Regen returns about 18-20% of the power back to the Pack as you go about your day, stop and go. That puts back about 18.65miles for a range of around 110miles.
I should mention, highway is less, about 85mi/kW BECAUSE unlike and ICE vehicle that gets much better highway then 'City' is because the ICE vehicle, old or new, once it's on a highway, the temp is the same, the mix is the same, the cooling is constant (you know, mostly), etc. All that gives the vehicles the optimal chemistry to get better MPG, or at least optimal for vehicles that don't have the aerodynamics of a refrigerator knocked over on its face with 4 wheels.
But for EVs, all EVs, the open road of a highway means that the EV motor is doing it's one job, full out - taking stored energy and providing it to the motor to turn (work). Even with mine and most modern EV motors running at 98.8% efficiency (truly amazing beasts), it's doing a 100% conversion from stored energy to work (driving) and that drains the Pack, efficiently but ruthlessly.
ALL that being said, AND ONLY in the world of Jeep does this dynamic fully benefit the Jeep owner.
The killer, magic ICE off-road vs EV off-road destroyer is:
idling.
Off-road, you lose so much to impossibly inefficient motor cooling and just sitting around, running, sipping or gulping gas.
Now, with an EV, there is NO IDELING, ever. And, EVs don't get hot, especially when not running fast. Are you getting it yet, did the bulb light up yet? Took me a LONG while to figure this out, I promise.
If there was a single breed of vehicle that was designed for EV in all it's glory, it would be a Jeep.
Imagine, sitting on a trail, hot day, full A/C, cooler, radio, charging phones or drone batteries, whatever and using less then 2kW of power with almost NO heat. You can drive without your shoes to protect your feet from catching fire from the floorboard. The EV A/C is only using 1.3kW of power to keep you cool while sitting there or going up a hill.
No idling in an EV Jeep. You lose around 5% of your fuel to sitting around. More with the A/C working it's little pistons to death, which, of course, adds more heat and causes more blah blah blah to the whole blah blah blah internal combustion blah blah blah.
You get it...
AND, I haven't even started going on and on about torque. You get 100% of your motors torque at 1RPM. For my builds, that's ~173ft/lbs of torque on demand, no ramping up, you just get it every second.
Does that explain what I mean by range is important but for a Jeep, it's clearly not the guiding factor of life. Everything that makes an ICE Jeep inefficient off-road is gone in and EV Jeep. Trust me, the irony of it all is not lost on me either.
Do a quick mental calculation - what do you think your actual MPG off-road is? And, what do you think an average weekend of driving off-road distance is - under 50 miles, by a lot, at least for me.
Also, a E-Jerry Can looks almost exactly like a small Honda or HF generator. 1 gal of gas in your little generator, back at the camp site, will give you about 20 miles of charge while you're sitting there, enjoying your adult beverage, chatting about the day on the trail.
So much to talk about, apology for the rambling on and on.
- Patrick
