97 Wrangler 2.5 starting issues
These jeeps are very sensitive to anything other than oem sensors. If you really want to put Chinese garbage in,save the old ones to be safe
Not sure who put what on this jeep..... I just took the old one out... in this case the fuel pump assembly and to be honest I dont understand saving something that does not work no matter if its OEM or not.
But thanks for your input...
I don't think you understand, I'm not referring to your fuel sender.
You are coming off as combative,try not to look at the advise you get as a contest with you. It is experience hard won.
Reactions: ItchyDong
Hey Rickyd, I apologize for how my post sounded...
I did not and do not understand your comment at all... I reacted to your Chinese garbage words.... maybe you meant the CPS?
Thanks for the input
Wanted to finish this thread off. The vehicle started right up after the install of the pump. Bad exhaust manifold to head leak. Can see at least one bolt missing. Drove it and I felt like I was driving a clown car. Seems to need some suspension work, breaks, shocks et al. I returned car to neighbor. At least she can move it around while she decides what she wants to do with it.
Thanks for the help
Reactions: macleanflood
