First a little background early in the year i replaced water pump. Then replaced radiator. AC WAS SERVICED LAST SEPT.
This spring it was noticed ac not working took back to shop fixed ac again they replaced the ac condenser this time. Ac has been working great temp up in 111 in vegas area i noticed temp on jeep has been operating over 210 in normal range. The other day i drove it for about 20 miles sitting at the light ",check gauses" light come up and it was near 260.then i shut off ac then the temp dipped to about 220 Then at times the temp climbs up to like 258 260 ....we shut off ac seems like temp will drop but not certain that is causing issue. I did notice shop replaced my OEM radiator fluid with green after maker universal fluid. Im wondering if the coolant is the problem? Any help would be great
