If you look in the pull down Tool menu under Math Parameters there is a fuel trims tab with combines trims separated by bank. Yes using pratio or map as an axis does allow you to identify areas of cruise, power decel, etc.. I mention decel because your DFCO is mostly likely still enabled which can skew things and you also have a few values around 10% + in these areas that I didn’t want to be confused in the conversation. If you log by bank you’ll see a variation between them.
OK. I found a video from HP Academy that was talking more in depth about injector scaling and the relationship with fuel trims.
After watching his video, he did an idle steady state test and a 3200rpm steady state test and discussed the difference that the injector setting play in the AFR across those two points. I then did an idle only log and wound up with about -2% LTFT+STFT. Then I did a steady 3500rpm drive and logged it and saw an average -4% LTFT+STFT.
During one of my 3500rpm attempts I dropped over a little knoll in the road and suddenly my numbers shot really negative so I moved to a new rpm cell, got ~-4% then let off a little and it dipped again. This is the Decel fueling you were talking about, right?
Thank you for your patience. I'm learning and I think my hang up was I don't know how everything interacts yet. I knew the trims didn't look like I expected but didn't know how to express the exact issue.
Theres a really long interstate hill climb not far from town that I can see I'm going to be driving up A LOT in the near future to get steady load logs.
