Hi everyone,
I recently sent an email to WranglerFix about this and I’m waiting for their response, but I wanted to post here as well in case anyone has seen the same issue. Maybe it can also help others who run into something similar.
Vehicle details:
Background:
After installing the PCM a few months ago, my transmission issue was completely resolved (thanks WranglerFix!). However, ever since then I’ve been seeing DTC P0516 – Battery Temperature Sensor Circuit Low right at key-ON.
What I tested:
Question:
Do WranglerFix PCMs intentionally fix the BTS reading to ~34 °C?
Has anyone else with a WranglerFix PCM seen this P0516 code at key-ON?
Any feedback would be really helpful — both for me and for anyone else who might face the same situation.
Thanks,
Enrique Meza
Vehicle details:
- 2005 Jeep Wrangler TJ SE
- 4.0L, 42RLE
Background:
What I tested:
- Monitored live data for Battery Temp and BATT TEMP SIGNAL.
- Tried the circuit open (no sensor), with resistors (4.7 kΩ, 10 kΩ, 22 kΩ), and with the actual sensor (~8.7 kΩ at ~34 °C).
- Verified wiring continuity from the connector to the PCM.
- In all cases, the scanner always reports ~34 °C (≈1.92 V). The value never changes regardless of resistance applied.
- It looks like the calibration is substituting a fixed default value (~34 °C) instead of reading the BTS.
- The P0516 code does not appear on the instrument cluster, only when scanned.
- I don’t mind the code itself, but I want to confirm if this is normal behavior and if it’s safe for long-term use, especially in a warm climate (La Paz, Mexico).
Question:
Thanks,
Enrique Meza
