At the outset I’m going to say the root cause Is I relaxed and let someone else do the measuring on this little project-
So a customer contacts me and she wants this arrangement, go from a side-by-side conventional washer dryer to over and under with a cabinet to the right , but no door over the washer dryer-
This is the easiest thing in residential cabinetry. You have a 67 inch opening. Her current washer and dryer sit beside each other.
All washer /dryers are 27-28 inches so you leave 30 inches and build a 37 wide inch tower-
Then you put a head
trim and its done.
Not us.
We start by making a cabinet for the washer and dryer which was the stupidest thing I’ve ever seen-
You’re telling me we built the hole on the left?
This shorted her box width 5”
And gave her nothing, complicated the install greatly
- so we scratched it and rebuilt it
We can’t suffer enough.
So I get into the middle of things and tell the worker there is no reason for that once you make the cabinet on the right you’ve got the hole. You’re making this way too complicated.
So he comes up with this
Again we don’t need anything around the washer and dryer. Don’t do anything around the washer and dryer. Nothing.
In the process of putting these in we figure this out- my guy Norm Abrams did not factor in the light when established depth- This is after the install taking 10 hours, 30 man hours. This is the most ridiculous thing I’ve ever seen- we can put a kitchen in in about half that time.
So we take 3 inches off the cabinets and start the install over again and we still have a clearance issue and we bring in the electrician
So now we’re moving the light and fixing the sheet rock and repainting the ceiling but not so fast-
The appliances won’t go in the opening - that we did not even need.
To make it worse is got a folding table and he’s got that neck high on her
This point I am hot as a firecracker and highly embarrassed and I get in the game and we’re going to rebuild everything to my specs -
Now with this plan the first thing is the base is tall enough you don’t have to do anything to the existing baseboard.
You build two boxes and put them in.
You install the face frame
You install a one by six across the top
Then her crown
And leave.
So help me. I spend nearly half of my time defending my company from its own people.
Then you put a head
trim and its done.
Not us.
Then her crown
And leave.
