I have a 2000 wrangler with a 99dakota swap and someone stole my pcm. How can I find out which pcm I need to get the right one. Also when I get used pcm do I give my tj vin to be programmed to the Dakota pcm thanks in advance
Since it has a Dakota engine and presumably transmission I suspect you need a Dakota PCM. WranglerFix might know the answer but I bet a Wrangler PCM is not what you need. But, I don’t know for certain as I don’t know much about the Dakotas.
Top of the morning to you from soggy South Florida. We do not have a bunch of DBA’s. I cut my teeth with Diesel ecms when I first started and ur never left me.
I think the 99 Dakota Ecm is what you need what size engine?
PS
If you have ever owned a Dodge Chrysler Jeep ram and not changed the computer, you have not owned it long enough.
PS
