Recently purchased a Sony XAV-AX3200
https://www.amazon.com/gp/aw/d/B09P9JTC8Z?tag=wranglerorg-20
With this rear camera, acam4 voxx
https://www.amazon.com/gp/aw/d/B08C1TCVZF?tag=wranglerorg-20
So I’ve been trying to get this thing right for the last day and a half. I’ve read and watched way too much for this thing not to work. The wiring harness for the camera has 3 total red (+) trigger wires and a (-).
The one closest to the radio, I went ahead and married it to the reverse in wire and plugged the yellow into the camera input. Easy.
The other 2 (+) wires, I have tried to wire just 1 to the reverse trigger wire 12v+ directly to the backup wire (purple/black) and left the middle one capped. DIDNT WORK. I then tied both (+) wires together and spliced them into the reverse trigger wire(purple/black).
The ground wire, hooked it behind the a bolt that holds the tailgate housing to body, fastened with a nut. Blew the fuse. Replaced and put the ground to an easy access spot in a license plate bolt. In doing so, I was able to atleast get the radio to shut off when putting in reverse but still no picture and when put back in P, radio comes back on.
1) Do all 3 (+) red wires need to be tied into something for the camera to work?
2) why did a fuse blow when I mounted the (-) to the body behind the taillight bolt?
3) will a larger gauge wire spliced with a 22g blow a fuse, specifically related to radio and camera wiring?
