Exploring options for comms.
I have a Midland CB that I have yet to install. It was previously in one of my JKs and my memory of it was that setup was extremely finicky. Never really got it to operate at it’s max.
Deciding whether it makes sense to switch to Midland MXT275 GMRS which seems to be plug and play.
Two questions…
Can the cable for GMRS be routed in the same bundle as 12v power or will that create static/interference? I have a bundle of aux wires running along the passenger side rocker above the jack tools and that would be the perfect route for the rear mounted antenna.
The preferred mounting location for the antenna would be on the upper arm of the Bestop HighRock Oversize Carrier. Possibly using a billet aluminum mount like this…
All points where the tire carrier mounts to the tub are insulated with rubber pads, effectively eliminating any grounding of the carrier components. Does a GMRS antenna rely on ground plane and if so could I wrap the coax for the antenna with a braided ground wire run back to the tub?
I’d like to have the mount such that I can switch between the standard antenna (if possible), the 3db Ghost antenna and a 6db whip.
An alternative would be to use the Midland Rollbar/Mirror mount in the same location or bumper/frame mount as pictured on the Midland site…
The latter would mean a much shorter run of antenna cable, eliminate the bundling with 12v wires and resolve the grounding concerns If there actually are any…
Two questions…
