I have decided to add an onboard air system to my 1997 TJ with a 4.0. After much consideration, have decided to use the ORO kit. I understand that the compressor may be a bit smaller than others have used but I feel it will be right for me and my needs plus it allows the continued use of the stock air box (Edit - ORO has updated their description and it does not work with the stock air box) and does not appear to need a coalescing filter (unsure in this part).
The kit comes with a length of steel braided line to deal with the hot air coming out of the compressor that I will use to take it to a manifold. From there, I will:
(A) Run a line to each side of the Jeep to couplers on the frame below the doors to allow a short hose to be used to fill tires and blow out the interior. In this scenario would it be best to run one line back to the passenger side (same side as compressor), split it and run it across to the drivers side or run one line from the passenger side and one line across the firewall and the down then driver side frame?
It seems that going down each frame rail would allow the hose to be more firmly secured vs crossing under the frame but I would like to hear / see what others have done.
OR
(B) Simply run one line down the passenger side frame rail and one to the front bumper. To me this is less than ideal for two reason (1) it is not tucked away and out of sight (2) Not a deal breaker but would need a longer airline to inflate tires / blow out interior.
OR
(C) Some great line routing suggestion that comes out if this thread.
Thoughts? Pictures?
