If I had a hydraulic lift I’d probably be done by now but laying in the driveway and trying to weld on my back is tricky and exhausting lolOOOF good luck, I don't envy that install
I admire your tenacity..A few more shots of the rusty skid plate bolts and transmission mount. It wasn’t the worst I’ve seen but it was definitely bent up and rusty
Drove it to work today!!!! Yep 52deg at 65mph is pretty chilly, but the drive home in the 80's is worth it!!!View attachment 324645
That repair looks awesome sturdy !!! I might have to do the same on mine, thanks for sharing.Got some free child labor for about 10 minutes. By the look on her face she loves it as much as her old man does lol the pile of rust is only from the driver side. I have the outside of the driver side cap welded all in. I’m going to move to the passenger side now so I can get the skid lined up before doing the inside welds.
The pre fabricated pieces are definitely sturdy as long as you have something to weld to and can run a decent bead lolThat repair looks awesome sturdy !!! I might have to do the same on mine, thanks for sharing.
I just found a mopar trans mount thought I’d put it on and thought I’d go for the trifecta since I just did new mopar engine mounts w/spacer lift,took it off and it was all broke and using only the failsafe bar to hold it together!A few more shots of the rusty skid plate bolts and transmission mount. It wasn’t the worst I’ve seen but it was definitely bent up and rusty
I’ve read a lot of stories about people getting knock offs such as anchor and a few others. I got the prothane one just because it has to be better than the one I had and the price was reasonable. I’ve heard they can cause vibration sometimes but everything already vibrates on my tj lolI just found a mopar trans mount thought I’d put it on and thought I’d go for the trifecta since I just did new mopar engine mounts w/spacer lift,took it off and it was all broke and using only the failsafe bar to hold it together!
Do you have a saab?Been there, done that. Had the T-shirt, but lost it in the fire…
Nope. Never could get used to plugging a key in between the front seats…Do you have a saab?
Sorry for your lossNope. Never could get used to plugging a key in between the front seats…
