Wrangler TJ Fluid Capacities & Fluid Recommendations
What about torque converter... After removing all the transmission, do we need to add oil to the torque converter before re-installing transmission?
Envoyé de mon MHA-L29 en utilisant Tapatalk
I've never owned a 32RH personally, so I'm reluctant to answer. @Jerry Bransford, do you know?
No, it will fill up on its own when the engine is running and the transmission is in Neutral. Nope it won't refill if the transmission is in Park so do shift to Neutral to get the ATF pump to run. That's also how you have to check the ATF level, with the engine running and transmission in Neutral. When the transmission cooler, torque converter, and 32RH are empty it'll take nearly 9 quarts of ATF+4 to refill everything.
You can partially fill the torque converter before reinstalling it to help it 'hook up' more easily in the beginning.
Drive and check the fluid several times, the ATF level will usually drop as it circulates so while it may be full in the garage, odds are it won't still be full after driving it.
Reactions: Medali
Thank you Jerry
Reactions: Jerry Bransford
Automatic Transmission Fill Procedure per the FSM
32RH and 30RH (97-02 3 spd auto)
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
  1. Remove dipstick and insert clean funnel in transmission fill tube.
  2. Add following initial quantity of Mozart ATF Plus 3 to transmission:
    1. If only fluid and filter were changed, add 3 pints (1-1/2 quarts) of ATF+4to transmission.
    2. If transmission was completely overhauled, torque converter was replaced or drained, and cooler was flushed, add 12 pints (6 quarts) of ATF+4to transmission.
  3. Apply parking brakes.
  4. Start and run engine at normal curb idle speed.
  5. Apply service brakes, shift transmission through all gear ranges then back to NEUTRAL, set parking brake, and leave engine running at curb idle speed.
  6. Remove funnel, insert dipstick and check fluid level. If level is low, add fluid to bring level to MIN mark on dipstick. Check to see if the oil level is equal on both sides of the dipstick. If one side is noticeably higher than the other, the dipstick has picked up some oil from the dipstick tube. Allow the oil to drain down the dipstick tube and re-check.
  7. Drive vehicle until transmission fluid is at normal operating temperature.
  8. With the engine running at curb idle speed, the gear selector in NEUTRAL, and the parking brake applied, check the transmission fluid level. CAUTION: Do not overfill transmission, fluid foaming snd shifting problems can result.
  9. Add fluid to bring level up to MAX arrow mark. When fluid level is correct, shut engine off, release park brake, remove funnel, and install dipstick in fill tube.
First it says to "Add following initial quantity of Mozart ATF Plus 3 to transmission:" And then below it lists the correct "ATF+4". I assume the first is a misprint in the FSM? Might want to change that if I'm correct. Maybe I'm reading this wrong?
I'll keep looking but is there an instruction posted for removing AT trans fluid, filter and gasket/pan someplace?
Should be ATF+4. Looks like a misprint to me.
Great info in this thread.
I'll be installing a new gasket/filter and trans fluid this weekend, on my 1998 TJ 4.0 32RH auto trans. The new gasket is supposedly rubber.
Should I use some gasket sealant/dressing? If yes, is there a recommended sealant, and should it be on both sides of the gasket?
I just ordered in the mopar coolant from amazon linked on pg 1, and this is supposedly OAT coolant. Is there a difference? 4.0 6 cyl
Maybe dumb question. Going to be changing coolant for first time. Is the 10.5 quarts the amount of non-premix coolant I need to get or do I only need to get half that cuz the rest is the water I will add?
I was told steering fluid needs to be changed at 100k miles. Is that correct? Any recommended brand and type?
Thank you
Here's a list of the different fluid capacities for various Wrangler TJ models.
Engine
2.5L 4 cyl - 4 quarts
2.4L 4 cyl - 5 quarts
4.0L 6 cyl - 6 quarts
Transmission
30RH 3 speed auto
ATF+4 is replacement). See post #2 below for fluid amount. Make sure to use ATF+4, not just ATF!
32RH 3 speed auto
Approximately 4 quarts ATF+4 is replacement) when drained via dropping the pan / Approximately 8 quarts dry fill. See post #2 below for FSM procedure. Make sure to use ATF+4, not just ATF!
42RLE 4 speed auto
Approximately 4 quarts ATF+4 when drained via dropping the pan / Approximately 8.8 quarts dry fill. Make sure to use ATF+4, not just ATF!
AX-5 5 speed manual
3.3 quarts 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals). I highly recommend Redline MT-90.
AX-15 5 speed manual
3.32 quarts 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals). I highly recommend Redline MT-90.
NV3550 5 speed manual
2.1 quarts. I highly recommend Redline MTL.
NV1500 5 speed manual
2.4 quarts. I highly recommend Redline MTL.
NSG370 6 speed manual
1.58 quarts. I highly recommend Redline MTL.
Transfer Case
231
1.1 quarts ATF+3 or ATF+4
241
2.1 quarts ATF+4
NOTE: The 231 and 241 transfer cases are fine with any type of good quality ATF. Mercon, Dexron, ATF+4, etc. are all fine. Only the automatic transmission is fussy about the type of ATF it gets.
Axles
Dana 30 - 1.25 quarts 75W-140
Dana 35 - 1.75 quarts 75W-140 *
Dana 44 - 2 quarts 75W-140 *
Rubicon Dana 44 (FRONT) - 1.375 quarts 75W-140 synthetic
Rubicon Dana 44 (REAR) - 2 quarts 75W-140 synthetic **
* 4 oz of friction modifier is required with Trac-Lok limited slip differential.
** Friction modifier is NOT required with Tru-Lok locker/limited slip differential (factory Rubicon locker).
Cooling System
The Jeep Wrangler TJ came with a HOAT coolant from the factory. I always recommend running OE Mopar coolant or Zerex G-05, which are both HOAT coolants.
2.5L - 9 quarts
2.4L - 10.1 quarts
4.0L - 10.5 quarts
I purchased a 2004 TJ v6 5-speed manual. I see there are a few different types of manual transmissions between 2000-2006 models. How can i find out which transmission I have ? Based on my research so far i believe its the NV3550 but i want to be sure, as i want to replace the fluid and my local auto part stores are telling me to use 80w-90 gear oil as I live in The Bahamas. Looking forward to your help.
Your TJ has a NV3550 transmission if it’s a 2004 6 cylinder.
Engine
Transmission
30RH 3 speed auto
32RH 3 speed auto
42RLE 4 speed auto
AX-5 5 speed manual
Transfer Case
231
241
2.1 quarts ATF+4
Axles
Cooling System
2.5L - 9 quarts
2.4L - 10.1 quarts
4.0L - 10.5 quarts
Thank you
