TJ's TJ
Your ability to take this on is impressive on its own but the fact that you have documented everything to a T and let us all tag along is admirable. Reminds me of restoring CJs with my pops. Good on ya.
Thanks. Documenting on this forum is a good way of keeping motivated to make progress believe it or not...
Reactions: PointerTJ
I had a separate post on this, but adding to the build thread. Steel Sub-Woofer enclosure.
I can get 1/4" steel cut to size at work, so we decided to build a Steel Sub enclosure. Research online said that it wouldn't sound good, but it sounds pretty good when paired with our Polks. Anyways, here are some details on the build:
Plasma cutters are good to have:
Here is the enclosure tacked together:
Seams were then fused with the TIG:
Added Roadkill Stinger Extreme damping material inside:
And about 1lb of polyfill:
Amp, sound processor (improves bass output signal into the sub amp from the factory radio) and sub in the box:
Drilled holes (very carefully due to Gas tank) for Riv-nuts:
A trick I learned somewhere along the way to prevent the drill bit from getting caught and dragged in when drilling thin metal:
Riv-nuts in:
What a phenomenal build/restoration thread! I look forward to the finished product. It looks like you are almost there!
Our jeep didn't come with a prop rod holder. there are 2 piece plastic ones on ebay that say they will fit a 99, but our hood does not have the rectangular hole for this style of clip so buyer beware.
I decided to design my own and during my search online of how the original clip mounts, I came across this one in Thingiverse that uses the original hole for the spring clip:
https://www.thingiverse.com/thing:2852748
Printed one up:
Added a 4mm rivnut:
Job done, it works perfectly:
Reactions: bedhed
Looks like you’ve already done it, but there’s a hydraulic hood support available too. Looking brand new as always
Sub is in and adjusted, sounds great.
We ran the cable for the adjustment knob up to the lower switch panel and out the cigarette lighter hole and mounted the knob just under the switches.
Reactions: JMT
The drivers side visor mount was broken so we copied the passengers side design in Solidworks. 2 hours later, we had one printed in Pet-G:
Also added a wireless charger:
Reactions: JMT
Yes, he still has 4 months to his permit, we will be registering it soon though now that the snow is clearing, but he will have to be a passenger for now.
That's just so cool you guys built that together. I have always wanted to build a car with my Dad. Closest we have come is a Golf Cart, which turned out pretty cool. He has kinda lost the drive to do a vehicle now...even though I tell him all the time how much we could do to his Jeep (2017 JK).
Reactions: JMT
I'm a little late to the party, but I jumped in at page one, got sucked in and read to the end. Wow! Now this was a true build. Fantastic restoration work. I'm impressed. Thank you for sharing.
The funny thing is that none of his friends get it, they just can't understand why anyone would want an old jeep that needs a ton of work...
He's fortunate to have you there, willing and able to take on this project with him. I'm sure he's proud of the build.
He will be the one in his group of friends that doesn't fumble around to locate the dipstick. An upbringing like this is priceless.
Thanks, Yes, its been a good experience. It is good to see him genuinely interested in mechanical things the way that I always was. I think you either have that or you don't. He seems to. He got himself onto the robotics team at school as well and he really likes that, so looks like it may continue on.
Reactions: bedhed
Picked up a gallon of Fluid Film and the Fluid Film Pro Gun to spray inside the frame.
Started by putting tape over all of the holes:
Here is the pro gun with one of the extension nozzles:
This stuff is thick! I had it in the house at 70 degrees... Took a lot of stirring and I even started blowing my heat gun into it as I stirred to get it to soften up. Eventually got it pourable. Sprayed it at about 100 psi at the gun.
Put about 1/4 of the can into the frame. Garage now smells like a barnyard.
We also got the Hardtop out and replaced the bottom seals:
And got the doors on:
As it sits, it is about 1" higher in the rear, but it only has a few gallons in it, we may add some spacers up front.
My hours of calculating backspacing and tire widths for tire stickout, worked out well. Tire stickout past the wider OEM flares (Rubi and Sarah) is perfect at about 1":
Could be the angle. But it appears that the rear axle could be pushed back towards the rear. Seems as if the axle is line centered in the rear wheel well.
