I worked on three different parts to print on the Bambu today: 1) the center console insert, 2) a dust cover for the slots in the center console that the cutting brake levers will ride in, and 3) plugs for the large holes in the top of the front frame-side spring mounts.
Center Console Insert
After some frustrating work, I was able to remove all the support from the PETG HF test piece and fit it up, and as I suspected, I have some revisions to make in order to clear everything. That is a work in progress, and I'm also making some changes regarding the difficulty removing the supports. I don't have any pictures to post, yet.
Dust Cover for Cutting Brake Lever Slots
I thought of this a few days ago. For months, I've been contemplating what to do to keep things from falling into the console, never to be seen again, through the slots I cut for the cutting brakes. I had thought about brushes, like the parking brake lever, but that'd be a bit cumbersome to make look good. It suddenly occurred to me that I can print a dust seal in TPU and try that. So, that was my first project of the day. Here's the model I ended up with:
Here's the printed part:
The slot is purposely off-center because the lever is off-center in the slot (hey, nobody's perfect!) I used TPU 95A HF with PLA as the support for the inner lip, and unlike the center console insert, the support easily peeled off with no residue. Yay! Here it is installed:
That was a "proof-of-concept" piece, and I think I can make it work. I'm going to have to match the contours on the left one in the picture above, for sure, because it won't fit the goofy top and bottom of the slot (I tried). I'm also going to try TPU 90A, which is a bit softer. The TPU 95A HF seems like it will work fine, but I'd like to try softer, just to see if it works better (or worse).
Plug for Top Front Frame-side Spring Mount
@sierradmax requested a print file for this part, and I saw
his request this morning. I wasn't even aware that there was a huge hole up there, and I can see the benefit of having it plugged. So, I went to work. It's actually a pretty easy part to model, and since I was already printing TPU 95A HF for the slot cover above, it was easy to print at the same time as the slot cover. Here's the design:
I put four small notches (circled above) in the top so that a screwdriver can be slipped in to remove it, but I don't think it'll be necessary. I was able pop it out with my fingers. There's a small lip to hold it in, too. Here are the two pieces I printed for the LJ:
And here's a shot of it installed:
If you'd like to download the files for the plug, I put it over
here. Merry Christmas!
I'd like to start another test print of the center console insert this evening, but I have a fair bit of modeling to finish in order to do so. It may have to wait for tomorrow. Stay tuned!
