So far, that is an accurate description of what you see when you go forward and then reverse. The squeal on the white paint used on crosswalks is also normal, especially if they are slightly wet.
I suspect we need some manner of a digital movie showing the problem.
I’ll try to record something, but I’m afraid it might not be visible on the video.
Today I loosened all the control arms and the Panhard rod, and then tightened them under the load of the engine and body, but it didn’t solve anything.
“I measured the distance between the front and rear rims… after driving forward and then backward, and the measurements were the same.”
sorry,It’s not very easy to see, but at the beginning of the video, you can see that the top of the wheel sticks out more. When the car moves forward, the top pulls inward and the bottom of the wheel moves further inside.”
Before filming, the car had been put in reverse.”
I don't see anything abnormal. How did you first discover the issue, since you can't see it while driving?
Put it on jackstands and put it in drive, and let it idle. see if the hub is also moving the same way.
Yes, I could try this… should I take the wheels off?
