This is a long story and I’m sorry because I know many people have posted about this, but I have gone through many posts and have yet to find a true answer. ANY advice would be appreciated… I have a 2005 Wrangler X, 108k miles, I’ve done nothing but pleasure drive this baby since I got it in 2011 at 33k miles. I do not rock climb and I barely off road it. It’s safe to say I baby it to compared to other Jeepers. I’ve done all the maintenance work to it routine oil and transmission changes etc, with that said, I have no clue why I’m having this problem…
Okay, flash back to a few months ago, like 2-3 months. I was driving to West Texas to drop my jeep off at a family members, which was a normal 3 hour drive. I over heated midway, randomly. I pulled off the road and it only took a few moments to cool down… I thought “Well, thats strange…” because this has never happened in the past. I get to my destination no problem BUT when I go to pick it up a month or two later, I had problems. I drove home and 2 hours in it seemed fine, i stopped for gas and BOOM overheating. I stopped the Jeep, waited a while for it to cool and go back on the road. As soon as i pulled into my driveway, BOOm again, over heating.
SO! Ive had off and on problems with over heating at an idle. At this point (week or so ago) I have replaced the thermostat, all hoses and the water pump. I topped the coolant off and tried again. When running it at idle in the drive way for about 16 minutes, it blew the radiator, just completely destroyed it. I thought well… its old… lets replace it to. So now radiator, running with new coolant, I start it up without the cap and no problems. As it gets hot, I have steam coming out the radiator. I know what you are thinking because I was thinking it too. Head gasket. I replaced the LAST THING I could think of. The fan clutch. I started it up, waited about 15 minutes, held at the normal 210. And then gave it some gas and THERE IT IS, spike in temp.
I would like to add. I AM NOT leaking fluid, Im not losing coolant, I have no coolant in my oil…I have no other signs that its a head gasket.
So… I’m trying to figure out if I'm missing something. This is the first and only Jeep I’ve had, and Ive never had problems. I know theres a chance it could be a head gasket but I have NO other traditional symptoms that show it’s for sure a head gasket. Im wiling to go down the rabbit hole because I truly don’t believe it. But I would like input on what other have experienced. Am I missing something or should i just say screw it, you’ve replaced everything coolant wise, it’s a head gasket.
