2006 Jeep Wrangler TJ SE
NOTE: Use this thread for entertainment purposes only — I have no clue what I’m doing. Any resemblance to actual sound advice is purely coincidental!
The goal of my Wrangler is to handle solo trips and the occasional weekend out-and-back runs with my three girls — usually 1 or 2 nights. It’s built to explore Idaho’s mountain roads and tackle mostly green and blue trails in Moab and Colorado (using the FunTreks rating system). It’s not a dedicated crawler or overland rig — more of a reliable scout for exploring, light crawling, and short camping trips.
Where It Stands: [Updated 7/9/2025]
SUSPENSION / AXLE:
ENGINE / DRIVETRAIN:
VEHICLE ARMOR:
ELECTRICAL / LIGHTING:
EXTERIOR APPEARANCE:
INTERIOR MODIFICATIONS:
RECOVERY & EMERGENCY GEAR:
MISC GEAR & EQUIPMENT:
PLANNED MODS:
This is always evolving. I have a general vision for where I want to take it — but I’m also fully prepared to change things up as I go. The goal is a capable, budget-conscious build (well, “budget” in the sense that I’m not buying junk parts — quality still matters). Right now, I’m also trying to convince the Mrs. that we could run *two* TJs for our style of trail rides for less than what we dumped into that first Rubicon.
SUSPENSION / AXLE:
- RockJock Currectlync Steering System
- SkyJacker 2.50-Inch Dual Rate Long Travel Front Lift Coil Springs
- SkyJacker 2.50-Inch Dual Rate Long Travel Rear Lift Coil Springs
- JKS Manufacturing Quicker Disconnect Sway Bar Links for 2.50 to 6-Inch Lift
- JKS Manufacturing Rear Adjustable Sway Bar End Link Kit
- Camp Series Front Heavy-Duty Adjustable Track Bar
- OME ARB FKWTJ02 Old Man Emu Fitting Kit - Rear Trackbar Relocation
- Core4x4 - 2pc Camp Series Front Lower Adjustable Control Arms
- Core4x4 - 2pc Camp Series Rear Upper Adjustable Control Arms
- Rancho RS5000X Gas Shocks
- Stock (for now)
VEHICLE ARMOR:
- Motobilt - Stubby Front Bumper w/ Stinger
- Motobilt - Winch Fairlead Mount Bolt On
- Motobilt - Rear Rock Crawler Bumper w/ Receiver
- Barnes4WD Rear Bumper Tie-In Set
- Odyssey Battery Performance Series AGM Battery; Group 34
- Spiderwebshade TJ - Black
- Motobilt - A-Pillar LED Light Mounts for Jeep TJ/LJ
- Motobilt Aluminum Universal Fairlead Light Mount
- None yet
- Factor55 Hawse Fairlead 1.0"
- Factor55 FlatLink
- Jeep Hardware - Replacement Hardware
PLANNED MODS:
- VANCO 15" Big Brake Kit with BMB Pads for 15" Rims (Researching)
- Barnes 4WD Jeep TJ Bolt On Skid Plate
- Barnes 4WD TJ-LJ 6 Cylinder Engine Skid
- RockJock CE-9900 - TJ/LJ Antirock Front Sway Bar Kit (Noodling on this one, might be way further down the line)
- Baja Designs XL Sport
- Baja Designs S8 10" LED Light Bar
- Wheels & tires - (Researching) - replacing the PO's installed Baja MTZ's and wheels. Running them out for now.
- Rocker guards/sliders - (Researching options)
- Warn Winch (Jeep came with a smittybilt. It works. I'm using it for now. But it's a personal preference thing.
- Axles & Gears - I have a plan here but I don't want to have arguments. So I'll just post it when I do it.
- Genright Jeep TJ/LJ (24.5 Gal) Gas Tank & Skid Plate
