More interesting info from SPAL:
For those unfamiliar with the SPAL fan controller, it is a temperature sensor that outputs a signal in proportion to their fixed setpoints to control SPAL aftermarket fans. They also have an override max function that normally you hook directly to your AC or to an override switch (blue wire below). This is fine for your average small fan, but for a fan as powerful as this one is quite excessive (in my opinion).
But...
Apparently, this "override max" function is actually full analog control, and thus could actually be adjusted to any setpoint by simply adjusting the voltage applied, such as with a potentiometer. The fan simply operates at the higher of the two requested setpoints.
What this means is that we can use this pin to set a low minimum fan state for A/C (or just in general) without having to run it up to max. Meaning you can basically copy my entire control scheme with just a SPAL sensor and a potentiometer. Extrapolating this further, you could do this and still add an override max switch that bypasses the potentiometer, or heck even add a minimum speed control knob in the cabin, assuming you paid attention in high school electronics class.
Note that these sensors only work for the aftermarket SPAL fans for the reasons I noted a few posts back. But once the new 19" fans come out, anyone who adopts them can build a simpler control system using just the SPAL controller, a potentiometer, and a switch or two if desired. No need for the Lingenfelter controller, GM coolant sensor, or diode.
