Cooling fan upgrade comparison: Explorer 11-blade fan and HD clutch versus SPAL 19" 850-watt electric brushless fan
I know you guys enjoy all the building stuff but wouldn't the temp sensors that SPAL sells for their fans work with this Camero fan also? While not cheap they work.
Just the temp sensor
https://wizardcooling.com/i-30504353-brushless-fan-temperature-switch.html
With wiring harness
https://wizardcooling.com/i-30500789-dual-fan-spal-brushless-fan-wiring-kit-195f-sensor.html
Those are for the aftermarket SPAL brushless fans only. To discourage people from using OEM fans (like we are doing), they reversed the control logic in the aftermarket fans compared to the standard OEM fans and then changed their sensor offerings to only match the aftermarket ones.
So if you used that on this fan, your fan would turn on at 100% at the minimum setpoint temperature and then ramp down to 30% and then shut off at the maximum temperature.
There's also the issue that those sensors are designed for narrow temperature bands only, and make it harder to control the system without having the fan cycle as it fights the thermostat.
Thanks for the explanation...
Jeez the Apple of brushless fans
It’s funny. They sell almost all of their OEM brushless fan variants in the aftermarket variants as well, except for the 19” 850-watt fan that everyone wants.
I suspect they’ll eventually come out with an aftermarket equivalent especially if GM complains that their stock of Camaro fans keeps getting wiped out.
If I had to guess, they probably just assumed few aftermarket buyers would stomach the cost of a 19” brushless fan and would instead go brushed (or brushless but smaller) to save money.
Reactions: lBasket and Wildman
Can you update post 1 with your latest parts list and setup? Thanks
Interesting update:
So I ended up reaching out to SPAL to see if they were planning on coming out with an aftermarket equivalent. I actually got a fairly quick response, and learned a few things in the discussion:
  • SPAL does in fact plan to offer a 19" fan as an aftermarket option at some point. No hard details, but it will be brushless, and "certainly the most powerful fan in the aftermarket" to quote. Possibly some details being released later this year.
  • They hinted that one of the biggest concerns with releasing such a high-powered fan was if people would actually wire it up correctly.
  • Supposedly, there is an upgrade coming to the aftermarket SPAL sensors. No details yet on what this would involve.
  • I also asked if they would be willing to name an OEM application of the 1,000-watt version of this fan. As I expected, they declined to answer that. (Presumably that is proprietary information of their customer.)
Interesting update:
Are there any programmable aftermarket controllers you’d recommend that linearly ramp up the aftermarket fan like your oem setup?
Would there be a benefit to getting the aftermarket version beyond preserving the OEM inventory for OEM applications?
Well for one, you wouldn't have to cut up a shroud just to get the one part you need. 2nd, you could use the SPAL aftermarket controllers as well as the Lingenfelter or an Arduino
Reactions: MikeE024
Not needing to trim the e-fan fan down would be nice, but I really like the route you took blending the fan in with the TJ shroud.
I’m attempting to understand if the aftermarket version is more of an alternative or an upgrade to the oem version.
It sounds like the Lingenfelter and Arduino work for both versions. Using a narrow sensor for turning off/on and aftermarket version seems like a step backwards versus it ramping based on load.
Using the Lingenfelter settings you provided, the fan’s output when ECTs are 195-210 isn’t anywhere near full speed and imo the noise isn’t bad at all. However, the noise at full speed that we get with the override switch would be annoying to hear kick on during normal use.
More interesting info from SPAL:
For those unfamiliar with the SPAL fan controller, it is a temperature sensor that outputs a signal in proportion to their fixed setpoints to control SPAL aftermarket fans. They also have an override max function that normally you hook directly to your AC or to an override switch (blue wire below). This is fine for your average small fan, but for a fan as powerful as this one is quite excessive (in my opinion).
But...
Apparently, this "override max" function is actually full analog control, and thus could actually be adjusted to any setpoint by simply adjusting the voltage applied, such as with a potentiometer. The fan simply operates at the higher of the two requested setpoints.
What this means is that we can use this pin to set a low minimum fan state for A/C (or just in general) without having to run it up to max. Meaning you can basically copy my entire control scheme with just a SPAL sensor and a potentiometer. Extrapolating this further, you could do this and still add an override max switch that bypasses the potentiometer, or heck even add a minimum speed control knob in the cabin, assuming you paid attention in high school electronics class.
Note that these sensors only work for the aftermarket SPAL fans for the reasons I noted a few posts back. But once the new 19" fans come out, anyone who adopts them can build a simpler control system using just the SPAL controller, a potentiometer, and a switch or two if desired. No need for the Lingenfelter controller, GM coolant sensor, or diode.
But...
I can say that when I had issues with my temperature sensor SPAL was great about getting it diagnosed and then replaced by Wizard Cooling. I haven't had my Hemi running long enough to say if the 300 watt 16" fan is going to be enough or if I'll have to step up to either the 500 watt version or this 19" as it might be cheaper overall.
I do appreciate you adding this additional information about the wiring & that I could control the speed by adjusting the voltage on the Blue wire.
Reactions: Steel City 06
Awesome. I removed my question about adjusting the max because I figured you’d respond if it could be done. But, this is far beyond the capabilities I was wondering about.
For clarity, would this provide full adjustability for independently setting the min, max, and override function?
Not quite, but it would allow you to choose a minimum fan speed to use whenever AC is on, and/or set a minimum fan speed (up to maximum) in the cabin with use of a knob.
Temperature setpoints are still not adjustable, and if you needed that, the Lingenfelter controller would be your better bet.
If anyone is running one of these sensors, it could be interesting to play with. @NashvilleTJ or @Wildman, are you using the SPAL sensor on yours?
I do run the SPAL sensor in mine, driving their 500 watt brushless. The setup does work well for me, so no need to fool with it. But, when that 19"er, 1000 watt SPAL comes out...
:unsure:
