so what do you use to make sure your axle is centered in the wheel well? Hole on the frame vs something on axle? Just want to make sure that it's centered.
I guess I could measure 96.6 from rear axle center to front. Just thought I'd ask and see how you guys doing vs what I'm going to conclude to use.
The tires relationship to the wheel well changes through the suspension travel. It isn't a relevant measurement. In fact,trying to center it can compromise important things like bump stop alignment and steering/trackbar clearance.
The only measurements you need to do are when adjusting the trackbar to center the axle at ride height. And adjusting the arms so the axles are perpendicular to the frames centerline.the rest is done by trial and error so nothing but the bumpstops hit
If you need somewhere to start with a tape measure,set the arms to stock length. Then forget about that number and make the axles fit the jeep
