Setting caster?
Sean B
Winsted Connecticut
Looking to make sure I’m right page. I found a schematic for TJ rubicon Dana 44 that shows there is a 13.6 degree caster offset from the pinion. So I calculated this to be pinion up 8.6 degrees to get 5 degrees caster. Measuring off the flats in the front of the center section. Does this mesh with what others found. My baseline measurements were not accurate because all the bushings were so worn.
