I have upgraded the front track bar to axle but not the front track bar to frame!View attachment 300931
Anyone try these upgraded bushings 9/16 for track bar ?
Don’t start changing parts just yet.I have upgraded the front track bar to axle but not the front track bar to frame!
Ok, maybe another alignment?Don’t start changing parts just yet.
I agree. I am always suspect when it is a photo of the screen and not a printout with before and after specs.
/\ Fact /\An alignment machine is only as accurate as the technician.
I agree to that. But when they snap a photo without showing before and after numbers it always makes me wonder.On the screen or on paper should read the same.
/\ Fact /\
Your absolutely right, the Jeep drove much better before the alignmentI agree to that. But when they snap a photo without showing before and after numbers it always makes me wonder.
I just received the below (from someone who wishes to remain anonymous) who had virtually the same identical symptoms with the same height lift and same Pitman arm/track bar mount setup. He looked at your symptoms and they were identical to his....Yeah it’s mostly on the freeway with speeds above 50 when I feel the left to right to left feeling
And the technicians inaccuracies will show up on the screen.An alignment machine is only as accurate as the technician.
Comparing those two is like comparing a Category 5 hurricane with a gentle summer breeze.You can’t mistake death wobble for wandering.
The steering is going right left right left !
