Can too much toe-in cause bump steer?
Anyone try these upgraded bushings 9/16 for track bar ?
I agree. I am always suspect when it is a photo of the screen and not a printout with before and after specs.
An alignment machine is only as accurate as the technician.
Reactions: Jerry Bransford
Yeah it’s mostly on the freeway with speeds above 50 when I feel the left to right to left feeling
I just received the below (from someone who wishes to remain anonymous) who had virtually the same identical symptoms with the same height lift and same Pitman arm/track bar mount setup. He looked at your symptoms and they were identical to his....
"I think it's a combination between 6" of lift, a DPA and track bar drop bracket. I had this same issue when I was running 5.5 RE springs, a DPA and the track bar bracket.
Both you and Blaine were nice enough to recommend removing the DPA and track bar bracket, and lowering the lift, which fixed everything.
If he set it up to read your camber that far out there is no telling where he set your toe setting.
If they set up the machine to read the camber that far out then it is very likely they misadjusted the toe setting. A misadjusted toe setting can cause exactly what he is experiencing.
Reactions: Jablinski
The tires where balanced right before my eyes but the alignment dude was shady and so I have another appointment at a different location for alignment. My Jeep drove much better before the alignment so I suspect the alignment is off
