Hey folks, the AC is blowing, it's just not blowing cold. I've never worked on an AC before. Where should I start / how should I proceed?
Start by checking the basics! Here are some steps to help you diagnose the issue:
Check the Refrigerant Level: Low refrigerant is a common reason for a/c not blowing cold. You can buy a refrigerant gauge from an auto parts store to check this yourself, or take it to a shop for a quick assessment.
Inspect the A/C Fuse: A blown fuse can affect the a/c system. Check the fuse box for any blown fuses related to the a/c.
Look for Leaks: Inspect the system for any visible signs of refrigerant leaks, usually around hoses and connections. Use a UV dye if necessary, which can be added to the system to help locate leaks.
Check the Compressor: Make sure the a/c compressor is engaging when you turn on the a/c. If you don’t hear it kick on, there might be an electrical issue or it could be faulty.
Condenser and Cabin Air Filter: Ensure that the condenser (located at the front of the radiator) isn’t blocked by debris. Also, check and replace your cabin air filter if it hasn’t been changed in a while; a clogged filter can restrict airflow.
System Reset: Sometimes, simply turning the a/c off and back on can reset system electronics.
