35 x 16s
notnsuv
NOW I Know!
Spring Creek, NV
My aluminum 16" beadlocks are begging to get off the shop floor and on the trail, and they happen to be the correct backspacing (4.5") for my new -07 small Yukon hub kit up front, whereas my 3.75 BS Vision wheels are not. It's not that I need beadlocks.
It's a long story.
https://www.customwheeloffset.com/s...from=16&width_from=35&saleToggle=0&qdToggle=0
Can you choose your favorite?
Can you do it without rationale on why 16s are a bad idea? I know, load range E.
Or for half the cash I can buy new wheels for the new tires I have and let the BL wheels drive me NUTS!.
Sheesh.. sometimes options suck.
When I bought the 35's for my JT, the price difference between tires for the 17 and 18 inch wheels was about $50 per tire... meaning that upgrading to 17's my new wheels and spare tire was nearly free... I think there are similar price differences from 15 to 16.
I like Baja Bosses (I have two sets of them) but haven’t tried all the others.
Made by Goodyear now, was Cooper. They look a lot like the Cooper Evolution but the Evos are not available in the 315-16. Also I don't see stud holes on the Mickeys, not that I need them, but they are on the Evos. Nearly identical price as Cooper ST Maxx and more than STT Pro.
I'm thinking tweener.. tween MT & AT.
Edit: Add Mastercraft to the Cooper/Goodyear list. I don't see that they're less money than the other "brand" names, tho'. Maybe Walmart.
4.5" of backspacing is a little too much for a 12.5" wide tire.
Taking into consideration the Yukon manual hubs, 5 x 4.5?
My understanding is that 4.5 was desirable for that.
"If you go with the 27-spline kit you will want wheels with around 4.5" BS to counter the extra width of around 1.5" - 1.75" (opinions vary), so about .75" minimum of extra width on each provided by the 27-spline kit. Going with a 5x4.5 with around 4.5" - 4.75" BS will dial you in and will depend on if you prefer a wheel ultimately with the fitment of 3.75" or 4.00" (IMO, a 3.75" is perfect bc it's just a hint wider and provides more clearance from rubbing the swaylock if you ever get one". (I already have an Anti-Rock)
Reactions: Jerry Bransford
