Today was a long day. Here are a few tips.
1) If your going to do the Savvy Crossmemner first, remove the front driveshaft at the TCase yoke first. Otherwise, when you get to the SYE, it’s a pain to get to the four bolts since they are so far up and the crossmember is partially in the way.
2) have a drift to get the outeer C’s to line up with the inner C’s and you have to have the crossmember in at the same time. I made a drift out of an old rusty 10” nail and an angle grinder. pITA
3) when you are doing the SYE, have a good pair of snap ring pliers, small flathead screwdriver, small needle nose pliers, large flathead screwdriver and anything else you may deem helpful.
There are two snap rings and two lock rings to remove, and one lock ring to install (with the JB SS SYE)
4) the Currie angled trackbar relocation bracket ( that is such a mouthful to say) has a spacer that is a PITA to slide into the stock axle mount. Grind some material off one end to make it fit. Compliments to
@starkey480 for this idea.
5) before you install the spacer in #4 above, install the upper bolt on the rear passenger side. Otherwise you may never get to it, and you may never get to it anyway.
6) spread out some old blankets under the rig if you don’t use a trolley or a lift. That way you can put all your tools in it and slide it under the Jeep and vice versa.
7) be patient. Take your time. Do it in stages.
8) my exhaust is going to interfere with my shock body and trackbar. That is still to come.
9) this is a no joke mod. I had never done more than change the oil on an auto 3 years ago. This has been a journey for me, a challenge, and many of you have inspired me. Thank you. I still have questions
driveshaft will be 19-19.25” long.
