@DrDmoney, remember the video of the Rockpile I was going over and I was lurching and you saw that and offered me the 4:1 TeraLow? Well, I went over the rockpile again last night. I literally went through in less than 30 seconds and didn’t even stop. That 4:1 is awesome in the rocks. Thank you again!
You‘re welcome, I knew you were the right person to give it to.
Where is the video? No video and it didn't happen....
As you wish. Page 129
...carefully watch as the Texas Billy Goat jumps from rock to rock trying to smack his nads on one of them in a ritual...
I'm referring to the video of him crawling across it with the TeraLow in it so we can now see how smooth he is.
Reactions: Rick Flair and JMT
I had to drive on these shocks awhile. I’m now ready to give my shock report for the Fox Savvy TJ Valved offering on my Jeep. The weight of my rig is 4,008lbs without hardtop, and 4,123 with hardtop.
These are the shocks:
Front
https://savvyoffroad.com/product/fox-tjf4/
Rear
https://savvyoffroad.com/product/fox-tjr4/
Prior experience:
I’ve run stock shocks on a 2004 Sport, KYB on a 2003 Rubicon, old OME, Bilstein 5100’s, and Rancho 5000x on an 2005 X. These shocks were installed on the 2005 X along with a set of 4” Currie coils. Of all these shock setups, the ones with a good travel bias were the stock shocks, the OME, and the Rancho’s. Travel bias for the Fox’s is below
The Fox Savvy were driven on this setup:
33’s, with hardtop and without (slight improvement with), spare delete, rear seat.
Front Coils 16 3/4” (4 3/4” Lift)
Front Shock Travel 4 7/8” Up 4 5/8” Down
Rear Coils 12 1/4” (4 1/4” Lift)
Rear Shock Travel 5 3/4” Up 3 1/3 Down
Buttometer:
Stiffer than the Rancho 5000x. Possibly more control. Possibly as stiff as Bilstein 5100’s. The Rancho’s were more fun to drive IMO.
Onroad
Highways = good
poor neighborhood streets = terrible
Potholes = jarring
Washboard gravel = surprisingly pretty good
Off-road (aired down to 10 psi)
Hill climbs = good
Rock crawling = good
Woopdedoo’s = poor unless you really slow down
Overall one of those shocks you spent more money on so you say, “I’ll get used to it .” If they tuned it for the TJ, I’d like to know more. What weight TJ? Nothing special except they are pretty. I preferred the Rancho’s, but I would like to try them on my new setup before being certain. The Jeep feels entirely different
My rig weighs:
4008lbs without the hardtop and unknown amount of gas
4123lbs with hardtop and same unknown amount of gas.
Reactions: DrDmoney and Alex01
My rig weighs:
Rear seat and trail gear on board?
Thats way lower than I would have guessed.
Rear seat. No trail gear.
There’s really not much on the rig, and nothing that doesn’t have to be on it.
my biggest weight penalties:
front bumper and winch 99lbs
JCR rock sliders 90lbs
Rear bumper 39lbs
GTS is a small weight savings
TCAse skid is a weight savings
MCE fenders are a weight savings
I think it’s why I’m getting 4 3/4” lift front and 5 1/4” rear on the 4” Currie/Rock Jock Springs.
Rear bumper 39lbs
I get exactly 4 3/4” up front and 4 1/4” in the rear as well
I’m at 5 1/4” in the rear. I’m going to keep checking it, but 13 1/4” length now. It’s a bit much, but my rear bumper is 24” at the lowest point. It’s crazy high
I thought that was a typo. Are you measuring at the middle of the upper pad?
I’m measuring total spring length, not including the upper spring isolator.
By middle I think you mean exactly parallel to the frame in the outside of the frame. I’ll go measure again
Moved the axle slightly forward to clear the axle side trackbar bolt. Everything clears now and my WB is 93.5. That's pretty close to stock WB of 93.4. I'm happy with that for now.
I sent an email to Savvy Off-Road about sending the Fox TJF4 and TJR4 back. We will see what they say.
Are you putting the Ranchos back on, or trying the Black Max's? Took the wife on a trip to the coast over the weekend and drove the Jeep. With 60ish lbs. of gear in the back and my lovely bride in the passenger seat, the Ranchos were ok. They need weight.
Going back to Rancho’s
