I began my Spartan Locker install. I have the axles removed, carrier removed and ring gear removed. Cleaned everything up and now need to find time to get the locker installed and everything put back together.
Reactions: Mikester86
Got rid of rusty tube type front bumper...
...and took advantage of the sale that a couple of online Jeep parts places were having on the Smittybilt SRC front bumper.
Went to go install my freshly powder coated bumper but didn't test fit before I got it painted. Thought 4 bolts, frame tie ins, simple enough right?
Savvy skid interfearing with the lower side of the bumper.
I'm thinking a cut off wheel is my best option basically trimming the bumper then hitting the exposed metal with rattle can. Any other ideas? I thought about a BFH and heat but there goes the powdercoat...
Reactions: TJ Starting
Might be a bit sketchy, but can you unbolt the gas tank skid, lower it an inch, slide the bumper on, and then bolt the skid under the bumper lip? You would lose a quarter inch of height on the skid though.
after walking away in frustration and just taking other look I think that is what I’m going to try first. Threads on the bolts are pretty short as is but I think I would have enough to retighten.
yes, but bolts are easily replaced
Reactions: rasband
Dropped the tank about 2cms and it squeezed right in. Kept a floor jack under. I can't believe I didn't see this during the intial attempt
Got a full set of threads back on the bolts. All good.
Looks good, this poison spider bumper is clean looking
Cursed at it! Found a dreaded coolant leak at the tstat housing , upper hose. Changed both hoses..still leaks. Going to replace the housing, tstat, and clamps next. Just gotta find the right clamps now....pockets are almost empty :(
It does look very clean. Same one I have sitting in the garage waiting for me to get powder coated. Love the simple and clean look of it on your Jeep.
I took out the Bosch 4 way spark plugs and swapped them for OEM NGKs. The Bosch plugs didn’t look that bad or old, but throttle response wasn’t great or smooth. Now it feels like a new Jeep :)
I haven’t posted in this thread much. I got my TJ in December, and since then have done quite a few of the major maintenance procedures. I still have to do the transmission fluid and brake fluid. Pretty soon it will be on to ‘want to’ projects!
Reactions: dschwes and Fonz54
