I began my Spartan Locker install. I have the axles removed, carrier removed and ring gear removed. Cleaned everything up and now need to find time to get the locker installed and everything put back together.
Might be a bit sketchy, but can you unbolt the gas tank skid, lower it an inch, slide the bumper on, and then bolt the skid under the bumper lip? You would lose a quarter inch of height on the skid though.Went to go install my freshly powder coated bumper but didn't test fit before I got it painted. Thought 4 bolts, frame tie ins, simple enough right?
Savvy skid interfearing with the lower side of the bumper.
I'm thinking a cut off wheel is my best option basically trimming the bumper then hitting the exposed metal with rattle can. Any other ideas? I thought about a BFH and heat but there goes the powdercoat...
after walking away in frustration and just taking other look I think that is what I’m going to try first. Threads on the bolts are pretty short as is but I think I would have enough to retighten.Might be a bit sketchy, but can you unbolt the gas tank skid, lower it an inch, slide the bumper on, and then bolt the skid under the bumper lip? You would lose a quarter inch of height on the skid though.
yes, but bolts are easily replacedafter walking away in frustration and just taking other look I think that is what I’m going to try first. Threads on the bolts are pretty short as is but I think I would have enough to retighten.
Looks great!Dropped the tank about 2cms and it squeezed right in. Kept a floor jack under. I can't believe I didn't see this during the intial attempt
Got a full set of threads back on the bolts. All good.
Looks good, this poison spider bumper is clean looking
. I did that last weekend for the first time too. It was great. The pollen getting on everything gave me an excuse to clean up the inside.
It does look very clean. Same one I have sitting in the garage waiting for me to get powder coated. Love the simple and clean look of it on your Jeep.Dropped the tank about 2cms and it squeezed right in. Kept a floor jack under. I can't believe I didn't see this during the intial attempt
that seat bottom came out great...Is your fridge on bricks?
