2004 Jeep TJ Wiring Harness Questions
Have you looked at Car-Part.com ? It searches junk yards. Find a yard that has the harness and contact them to see if they will ship to Hawaii.
I found a harness on parts breakers that I purchased. It’s expensive but They offer 90 day return/exchange policy, which is the main reason I went w them. That and they ship to Hawaii. Hopefully this will resolve the issue.
Should have it in couple weeks, will update the post when it’s in.
You can send it to @Wranglerfix and he'll test it for you.
Might do that. Problem is the shipping, it’s so expensive that no matter what I do it’s always a balance between what option to do and the shipping. And, what can I afford afterwards if it doesn’t work…
I can buy a part for $50 and pay $150+ in shipping… it’s a potential wallet drainer every time I purchase something
I lived in AK and Germany so I understand the whole shipping part.
But if you're not sure about your PCM having it tested would be worth the expense for piece of mind.
Reactions: macleanflood
Part number for your engine loom depends on a few factors.
Engine, transmision, emissions package, brakes (disc/drum/abs), LHD/RHD. Might be able to find the loom part number if you can supply that info.
Even with that, if you can't get a replacement the FSM wiring diagrams might be needed to establish just what circuits you would need to replace the factory loom.
Hey J J- I purchased a wiring harness a day or two ago, which will replace all the wiring under the hood. Tired of troubleshooting electrical ghosts.
Wildman- I took your advice ( a bit to the extreme) and decided to purchase a PCM from Wrangler Fix. I figured if I'm going this far to replace the entire under hood wiring, I might as well just complete the process and replace the PCM.
Will take a few weeks for process to be done, but will update the thread when done.
Fingers crossed that all this will cure your electrical issues. I know how much of a PITA they can be and it's no fun trying to chase them down.
